Component: Serial EEPROM (24LC512) (EEPROM)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Version 2.2
Category EEPROM
Serial EEPROM (24LC512) component
Serial (I2C) EEPROM component for 24LC512
Please click here to download the component source project: FC_Comp_Source_Serial_EEPROM_(24LC512).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Serial_EEPROM_(24LC512).fcfx
Read
Read and return the value of the EEPROM at the given address
- UINT address
ReadPage
Reads and return specified number of values of the EEPROM starting from the given address
- UINT address
- BYTE data
- BYTE count
Write
Write the given data value to the EEPROM at the given address
- UINT address
- BYTE data
WritePage
Writes up to 128 data values to the EEPROM at the given address
- UINT address
- BYTE data
- BYTE count
Range: 1-128
Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Channel selection
Baud Select
Baud rate to be used
Stop Delay
SDA
SCL
Simulate Comms
No - Provides simulation using a local memory buffer Yes - Provides I2C simulation which can be passed via an API device to real world hardware
Read
- UINT address
ReadPage
- UINT address
- BYTE data
- BYTE count
Write
- UINT address
- BYTE data
WritePage
- UINT address
- BYTE data
- BYTE count
Range: 1-128
Device Address
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
Read
- UINT address
ReadPage
- UINT address
- BYTE data
- BYTE count
Write
- UINT address
- BYTE data
WritePage
- UINT address
- BYTE data
- BYTE count
Range: 1-128
Device Address
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
Read
- UINT address
ReadPage
- UINT address
- BYTE data
- BYTE count
Write
- UINT address
- BYTE data
WritePage
- UINT address
- BYTE data
- BYTE count
Range: 1-128
Device Address
Channel selection
Baud Select
Stop Delay
SDA
SCL
Simulate Comms
