| Author
Matrix TSL
| Version
1.0
| Category
EEPROM
Serial Flash (W25) component
Component to allow support for the Winbond W25 range of SPI Flash devices. Compatible with various sizes of Flash including: 2Mb, 4Mb, 8Mb, 32Mb, 64Mb, 128Mb.
Please click here to download the component source project: FC_Comp_Source_SerialFlash_W25Q.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_SerialFlash_W25Q.fcfx
WriteControl
| Enables or disables writing for things like erasing and programming. Writes must be enabled after a power on reset and again after an erase command.
- BOOL
Status
| 1 = Write Enabled, 0 = Write Protected
ReadStatus
| Reads one of the internal status registers on the device
- BYTE
Reg
| Selects which status register to read, 0 = Status or 1 = Status 2.
- BYTE
ReadDataByte
| Reads a single data byte from the specified address.
- UINT
PageAddress
| Address bits A23-A8 : 16-bit Address - Range 0x0000 - 0xFFFF
- BYTE
ByteAddress
| A7-A0 : 8-bit Address within the page - Range 0x00 - 0xFF
- BYTE
ReadUniqueID
| Reads the 8-byte unique identifier from the IC. Useful if you need each board to have it's own guarenteed unique address or identifier.
- BYTE
ID
| 8-Byte data array to store the unique ID read back from the IC.
WriteDataArray
| Writes an array of data bytes atarting at the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly. Note that all bytes will be written to the same page.
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
| Number of bytes to write.
- BYTE
Data
EraseChip
| Erases all data stored on the chip. Chip erase takes between 20 seconds and 100 seconds to complete. Blocking mode is recommended to ensure write cycle is complete.
- BOOL
Blocking
| Controls if the macro blocks until the erase cycle is complete. 0 = Don't Wait, 1 = Wait
WriteDataByte
| Writes a single data byte to the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly.
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Data
| Data byte to write
EraseBlock
| Erases a block of data stored on the chip. Erase takes between 45 milliseconds and 2000 milliseconds to complete. Blocking mode is recommended to ensure write cycle is complete.
- BYTE
EraseMode
| 0=4KB / 1=32KB / 2=64KB
- UINT
PageAddress
- BOOL
Blocking
ReadDataArray
| Reads up to 256 data bytes starting from the specified address. Note that all bytes will be read from the same page.
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
| Number of bytes to read.
- BYTE
Data
| Byta array to store the incoming read data.
| Initialises the SPI bus ready for communications.
Flash Properties
Memory Size
| Sets the size of the flash memory available on the chip.
Number Bytes
Number Pages
SPI Properties
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulate Comms
| Decides how the simulation handles the data. No - Do no SPI simulation and allow all simulation data to come from a local text file. Yes - Use SPI simulation for use with Injector components etc.
File Simulation
Simulation File
| Name of file to use to hold the contents of the simulated flash memory. $(srcdir) assigns the file to the same folder as the Flowcode project file.
Unique ID Lower 32-bit
Unique ID Upper 32-bit
WriteControl
- BOOL
Status
ReadStatus
- BYTE
Reg
- BYTE
ReadDataByte
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
ReadUniqueID
- BYTE
ID
WriteDataArray
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
- BYTE
Data
EraseChip
- BOOL
Blocking
WriteDataByte
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Data
| Data byte to write
EraseBlock
- BYTE
EraseMode
- UINT
PageAddress
- BOOL
Blocking
ReadDataArray
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
- BYTE
Data
Flash Properties
Memory Size
Number Bytes
Number Pages
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Simulate Comms
File Simulation
Simulation File
WriteControl
- BOOL
Status
ReadStatus
- BYTE
Reg
- BYTE
ReadDataByte
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
ReadUniqueID
- BYTE
ID
WriteDataArray
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
- BYTE
Data
EraseChip
- BOOL
Blocking
WriteDataByte
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Data
| Data byte to write
EraseBlock
- BYTE
EraseMode
- UINT
PageAddress
- BOOL
Blocking
ReadDataArray
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
- BYTE
Data
Flash Properties
Memory Size
Number Bytes
Number Pages
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Simulate Comms
File Simulation
Simulation File
WriteControl
- BOOL
Status
ReadStatus
- BYTE
Reg
- BYTE
ReadDataByte
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
ReadUniqueID
- BYTE
ID
WriteDataArray
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
- BYTE
Data
EraseChip
- BOOL
Blocking
WriteDataByte
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Data
| Data byte to write
EraseBlock
- BYTE
EraseMode
- UINT
PageAddress
- BOOL
Blocking
ReadDataArray
- UINT
PageAddress
- BYTE
ByteAddress
- BYTE
Count
- BYTE
Data
Flash Properties
Memory Size
Number Bytes
Number Pages
SPI Properties
Prescale
MOSI
MISO
CLK
CS / SS
Simulate Comms
File Simulation
Simulation File
