Component: Switch Rotary 0 - 15 (Switch)
Revision as of 09:59, 27 January 2023 by Wiki bot (talk | contribs)
Category Switch
Switch Rotary 0 - 15 component
Please click here to download the component source project: FC_Comp_Source_Switch_Rotary_0_-_15_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Switch_Rotary_0_-_15_2dgi.fcfx
SetPosition
Sets the switch to be on or off.
- BYTE Position
The new state of the switch (true=on, false=off)
GetPosition
Reads the button state as 0 for released or 1 for pressed Performs debounce if required
Num Positions
Pin 1
Pin 2
Pin 4
Pin 8
Common
Component Label
Show Position Numbers
Style
Style
Type
SetPosition
- BYTE Position
GetPosition
Num Positions
Pin 1
Pin 2
Pin 4
Pin 8
Common
Component Label
Style
Style
Type
SetPosition
- BYTE Position
GetPosition
Num Positions
Pin 1
Pin 2
Pin 4
Pin 8
Common
Component Label
Style
Style
Type
SetPosition
- BYTE Position
GetPosition
Num Positions
Pin 1
Pin 2
Pin 4
Pin 8
Common
Component Label
Style
Style
Type
