Author
Matrix Ltd.
Version
2.2
Category
Comms: Networking
TCP Template component
Base TCP/IP component with simulation only interface to allow TCP/IP style network communications in simulation. Suitable for inheriting
Please click here to download the component source project: FC_Comp_Source_TCPIP_Base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_Base.fcfx
Additional examples can be found in the “Apps and Bundles” section of this Wiki:
Internet Application Guide
Wireless LAN Application Guide
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
Specifies the communications channel 0-3
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
Specifies the value of the first byte
- BYTE
Byte2
Specifies the value of the second byte
- BYTE
Byte3
Specifies the value of the third byte
- BYTE
Byte4
Specifies the value of the fourth byte
- BYTE
SetPropertyVal
- STRING
Property
- STRING
Value
SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
First Byte of IP address
- BYTE
IP1
Second Byte of IP address
- BYTE
IP2
Third Byte of IP address
- BYTE
IP3
Fourth Byte of IP address
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE
- STRING
Data
Data byte to append to Tx buffer.
SecureWrite
Attempts to write max number of bytes to the secure socket from the buffer. Returns actual number of bytes written.
- STRING
buffer
- INT
max
- INT
Connect
Attempt to connect to the given address and port. First open a socket on the local device using the Socket function and check that it is successful.
- STRING
Address
Remote destination address
- UINT
Port
Remote destination port
- BYTE
ForcePropEvent
Allows the property event to be fired, doing things like fetching the correct IP for the network interface.
Receive
Receive data into the data buffer. Returns the number of bytes received
- STRING
Data
Data byte buffer to receive the data
- UINT
Count
Maximum number of bytes to read
- UINT
SendTo
Send data to a destination host. Returns the number of bytes sent.
- STRING
Data
Data byte buffer to send
- UINT
Count
Number of bytes to send
- STRING
Address
- UINT
Port
- UINT
SecureConnect
Connect securely to host and port. e.g. “www.bbc.co.uk:443” Returns 1 if successful, 0 if not
- STRING
host
Host:Port as string
- INT
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
Specifies the byte index to return
- BYTE
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
Specifies how many bytes to skip
CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE
- BYTE
Protocol
Specifies which IP protocol to use
- BYTE
Broadcast
Allows broadcast type packets to be sent and received
- BYTE
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE
- BYTE
Dst_IP0
Specifies the first byte of an IP address
- BYTE
Dst_IP1
Specifies the second byte of an IP address
- BYTE
Dst_IP2
Specifies the third byte of an IP address
- BYTE
Dst_IP3
Specifies the fourth byte of an IP address
- BYTE
Dst_Port_Hi
Port High Byte
- BYTE
Dst_Port_Lo
Port Low Byte
GetConsole
Obtain the console instance for the TCP/IP base.
- HANDLE
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'RxReadByte' (or any other read function) will read the next byte
- BYTE
- BYTE
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
Send
Send data
- STRING
Data
- UINT
Count
- UINT
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
Specifies the value of the fifth byte
- BYTE
Byte6
Specifies the value of the sixth byte
- BYTE
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
SecureClose
Close the secure connection
RxReadString
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
- STRING
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
SetChannel
Dictates the TCP IP channel used for socket communications allowing for multiple parrallel communication streams to co-exist, Used by the network comms component to drive the TCP IP runtime comms
- BYTE
Range: 0 to 3
Listen
Bind the socket to a port on the local host and set to listen mode. First open a socket on the local device using the Socket function and check that it is successful.
- UINT
Port
- BYTE
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE
- BYTE
SocketOpen
Attempts to create a socket on the local device. Type =0 for TCP, =1 for UDP This must be successfully done before attempting connection with a remote destination. Returns 1 if successful, 0 if not.
- BYTE
Type
Type of socket to create
- BYTE
TxSendByte
- BYTE
- BYTE
Data
TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
High Byte of destination port
- BYTE
Dst_Port_Lo
Low Byte of destination port
- BYTE
GetPropertyVal
- STRING
Property
- STRING
SocketClose
Close the socket
SecureRead
Attempts to read max number of bytes from the secure socket into the buffer. Returns actual number of bytes read.
- STRING
buffer
- INT
max
- INT
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
AcceptOpen
- BYTE
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- BYTE
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
AcceptClose
Close the accept socket
SecureInit
Call once to initialise the secure socket funtionality
GetSocketStatus
This returns the state of the requested channel's socket.
- BYTE
- BYTE
TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
Hostname
Local PC's hostname
Network Interface
List of network interfaces connected to the PC. Sets which interface we are communicating via.
Gateway IP
Gateway0
Gateway IP address to the Internet, auto populated from the selected interface.
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Network IP subnet mask, auto populated from the selected interface.
Subnet1
Subnet2
Subnet3
IP Address
IP0
Network IP address, auto populated from the selected interface.
IP1
IP2
IP3
MAC Address
MAC0
Network MAC address, auto populated from the selected interface.
MAC1
MAC2
MAC3
MAC4
MAC5
Notify
Generate Console Data
Target
Sets a target object, to which User.Notify events will be sent when data is sent and received. Events are send with Message ID = this component's handle, Data: 1=Send, 2=Receive.
TxSendMyIP
- BYTE
RxMatchMyIP
- BYTE
- BYTE
RxMatch_4_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
SetPropertyVal
- STRING
Property
- STRING
Value
SetMyIP
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendString
- BYTE
- STRING
Data
SecureWrite
- STRING
buffer
- INT
max
- INT
Connect
- STRING
Address
- UINT
Port
- BYTE
ForcePropEvent
Receive
- STRING
Data
- UINT
Count
- UINT
SendTo
- STRING
Data
- UINT
Count
- STRING
Address
- UINT
Port
- UINT
SecureConnect
- STRING
host
Host:Port as string
- INT
RxReadHeader
- BYTE
- BYTE
Idx
- BYTE
RxSkipBytes
- BYTE
- BYTE
Count
CreateIPSocket
- BYTE
- BYTE
Protocol
- BYTE
Broadcast
- BYTE
SetDestination
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
Port High Byte
- BYTE
Dst_Port_Lo
Port Low Byte
GetConsole
- HANDLE
TxStart
- BYTE
RxReadByte
- BYTE
- BYTE
CreateUDPSocket
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
Send
Send data
- STRING
Data
- UINT
Count
- UINT
RxMatch_6_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
- BYTE
Byte6
- BYTE
RxMatch_2_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
SecureClose
RxReadString
- BYTE
- BYTE
Length
- STRING
TxEnd
- BYTE
SetChannel
- BYTE
Range: 0 to 3
Listen
- UINT
Port
- BYTE
CreateTCPSocket
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
RxDataAvailable
- BYTE
- BYTE
SocketOpen
- BYTE
Type
- BYTE
TxSendByte
- BYTE
- BYTE
Data
TCPListen
- BYTE
RxFlushData
- BYTE
TCPConnect
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
- BYTE
Dst_Port_Lo
- BYTE
GetPropertyVal
- STRING
Property
- STRING
SocketClose
Close the socket
SecureRead
- STRING
buffer
- INT
max
- INT
RxMatchMyMAC
- BYTE
- BYTE
AcceptOpen
- BYTE
RxDataSize
- BYTE
- BYTE
TxSendMyMAC
- BYTE
CreateMACSocket
- BYTE
Promiscuous
- BYTE
Broadcast
- BYTE
Error
- BYTE
AcceptClose
SecureInit
GetSocketStatus
- BYTE
- BYTE
TCPClose
- BYTE
Hostname
Local PC's hostname
Network Interface
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Notify
Target
TxSendMyIP
- BYTE
RxMatchMyIP
- BYTE
- BYTE
RxMatch_4_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
SetPropertyVal
- STRING
Property
- STRING
Value
SetMyIP
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendString
- BYTE
- STRING
Data
SecureWrite
- STRING
buffer
- INT
max
- INT
Connect
- STRING
Address
- UINT
Port
- BYTE
ForcePropEvent
Receive
- STRING
Data
- UINT
Count
- UINT
SendTo
- STRING
Data
- UINT
Count
- STRING
Address
- UINT
Port
- UINT
SecureConnect
- STRING
host
Host:Port as string
- INT
RxReadHeader
- BYTE
- BYTE
Idx
- BYTE
RxSkipBytes
- BYTE
- BYTE
Count
CreateIPSocket
- BYTE
- BYTE
Protocol
- BYTE
Broadcast
- BYTE
SetDestination
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
Port High Byte
- BYTE
Dst_Port_Lo
Port Low Byte
GetConsole
- HANDLE
TxStart
- BYTE
RxReadByte
- BYTE
- BYTE
CreateUDPSocket
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
Send
Send data
- STRING
Data
- UINT
Count
- UINT
RxMatch_6_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
- BYTE
Byte6
- BYTE
RxMatch_2_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
SecureClose
RxReadString
- BYTE
- BYTE
Length
- STRING
TxEnd
- BYTE
SetChannel
- BYTE
Range: 0 to 3
Listen
- UINT
Port
- BYTE
CreateTCPSocket
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
RxDataAvailable
- BYTE
- BYTE
SocketOpen
- BYTE
Type
- BYTE
TxSendByte
- BYTE
- BYTE
Data
TCPListen
- BYTE
RxFlushData
- BYTE
TCPConnect
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
- BYTE
Dst_Port_Lo
- BYTE
GetPropertyVal
- STRING
Property
- STRING
SocketClose
Close the socket
SecureRead
- STRING
buffer
- INT
max
- INT
RxMatchMyMAC
- BYTE
- BYTE
AcceptOpen
- BYTE
RxDataSize
- BYTE
- BYTE
TxSendMyMAC
- BYTE
CreateMACSocket
- BYTE
Promiscuous
- BYTE
Broadcast
- BYTE
Error
- BYTE
AcceptClose
SecureInit
GetSocketStatus
- BYTE
- BYTE
TCPClose
- BYTE
Hostname
Local PC's hostname
Network Interface
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Notify
Target
TxSendMyIP
- BYTE
RxMatchMyIP
- BYTE
- BYTE
RxMatch_4_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
SetPropertyVal
- STRING
Property
- STRING
Value
SetMyIP
- BYTE
IP0
- BYTE
IP1
- BYTE
IP2
- BYTE
IP3
TxSendString
- BYTE
- STRING
Data
SecureWrite
- STRING
buffer
- INT
max
- INT
Connect
- STRING
Address
- UINT
Port
- BYTE
ForcePropEvent
Receive
- STRING
Data
- UINT
Count
- UINT
SendTo
- STRING
Data
- UINT
Count
- STRING
Address
- UINT
Port
- UINT
SecureConnect
- STRING
host
Host:Port as string
- INT
RxReadHeader
- BYTE
- BYTE
Idx
- BYTE
RxSkipBytes
- BYTE
- BYTE
Count
CreateIPSocket
- BYTE
- BYTE
Protocol
- BYTE
Broadcast
- BYTE
SetDestination
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
Port High Byte
- BYTE
Dst_Port_Lo
Port Low Byte
GetConsole
- HANDLE
TxStart
- BYTE
RxReadByte
- BYTE
- BYTE
CreateUDPSocket
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
Send
Send data
- STRING
Data
- UINT
Count
- UINT
RxMatch_6_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
- BYTE
Byte6
- BYTE
RxMatch_2_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
SecureClose
RxReadString
- BYTE
- BYTE
Length
- STRING
TxEnd
- BYTE
SetChannel
- BYTE
Range: 0 to 3
Listen
- UINT
Port
- BYTE
CreateTCPSocket
- BYTE
- BYTE
Src_Port_Hi
Port High Byte
- BYTE
Src_Port_Lo
Port Low Byte
- BYTE
RxDataAvailable
- BYTE
- BYTE
SocketOpen
- BYTE
Type
- BYTE
TxSendByte
- BYTE
- BYTE
Data
TCPListen
- BYTE
RxFlushData
- BYTE
TCPConnect
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
- BYTE
Dst_Port_Lo
- BYTE
GetPropertyVal
- STRING
Property
- STRING
SocketClose
Close the socket
SecureRead
- STRING
buffer
- INT
max
- INT
RxMatchMyMAC
- BYTE
- BYTE
AcceptOpen
- BYTE
RxDataSize
- BYTE
- BYTE
TxSendMyMAC
- BYTE
CreateMACSocket
- BYTE
Promiscuous
- BYTE
Broadcast
- BYTE
Error
- BYTE
AcceptClose
SecureInit
GetSocketStatus
- BYTE
- BYTE
TCPClose
- BYTE
Hostname
Local PC's hostname
Network Interface
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Notify
Target
