Component: TTI TG5011 Signal Generator (TG5011) (Test Equipment)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Version 0.2
Category Test Equipment
TTI TG5011 Signal Generator component
TTi TG5011 50 MHz Signal Generator
Please click here to download the component source project: FC_Comp_Source_TTITG5011.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_TTITG5011.fcsx
NOISADD
Select <ON> to add the noise to the output waveform and <OFF> to remove the noise from the output waveform. 0 = ON, 1 = OFF.
- BOOL Noise
Add/remove the noise to/from the output waveform (0 = ON, 1 = OFF).
PULSSYMM
Sets the pulse waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
- FLOAT Symmetry
Sets the pulse waveform symmetry in percent. (0 - 100)
BSTPER
Sets the burst trigger period to <nrf> seconds. (Lower limit: 1us - Upper limit: 500s).
- FLOAT Seconds
Duration of the burst trigger period in seconds.
MODAMDEPTH
Sets AM waveform depth to <nrf> %. (Lower limit: 0% - Upper limit: 120%).
- FLOAT Frequency
Sets AM waveform depth in percent (%) (0 - 120).
WAI
Wait for Operation Complete true. As all commands are fully executed before the next is started this command takes no additional action.
SWPBEGFREQ
Sets the sweep start frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 100kHz)
- FLOAT Frequency
Sets the sweep start frequency in Hertz(Hz) (1uHz - 100kHz).
MODFMFREQ
Sets FM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
MODFSKSRC
Sets FSK waveform source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets FSK waveform source (0 = INT, 1 = EXT).
MODPWMDEVSYM
Sets PWM deviation to <nrf> %. ?
- BYTE Deviation
Sets PWM waveform deviation in percent. (?)
ARB3DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB3.
- STRING Return
PER
Sets the waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms)
- FLOAT Period
Duration of the waveform period in seconds (20ns - 1Ms).
BEEPMODE
Set beep mode to; 0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR.
- BYTE Mode
Sets the beep mode (0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR).
SWPTRGSRC
Sets the sweep trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
- BYTE Source
Set the sweep trigger source (0 = INT, 1 = EXT, 2 = MAN).
PULSPER
Sets the pulse waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
- FLOAT Period
Duration of the pulse waveform period (20ns - 1Ms).
ARBDEF
Sets user specified waveform name <cpd2> and waveform point interpollation state <cpd3> of arbitrary waveform memory location <cpd1>.
- STRING Name
Specified waveform name
- STRING State
Waveform interpolatino state
- STRING Location
Waveform memory location
WAVELVL
Sets the output waveform level to <nr1> %. (Lower limit: 50 - Upper limit: 100)
- FLOAT Percent
Sets the output waveform level in percent (50 - 100).
CALVALRet
Returns the value from level calibration steps.
SWPENDFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz.)
- FLOAT Frequency
Set the sweep end frequency in Hertz(Hz) (1uHz - 50MHz).
ZLOAD
sets the output load, which the generator is to assume for amplitude and dc offset entries, to; 0 = OPEN or 1 - 10,000
- INT Output
Sets the output load for amplitude and dc offset entires (0 = OPEN or 1 -10,000).
MODFMSHAPE
Sets FM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets FM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
AMPLRNG
Sets the amplitude range to; 0 = AUTO, 1 = HOLD.
- BOOL Range
Sets the amplitude range (0 = AUTO, 1 = HOLD).
SYNCOUT
Sets the sync output to; 0 = ON, 1 = OFF.
- BOOL Sync
Enable/disable sync output (0 = ON, 1 = OFF).
SRE
Set the Service Request Enable Register to <nrf>.
- BYTE Status
ARB1Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
ARB2DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB2.
- STRING Return
FREQ
Set the waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets the waveform frequency in Hertz(Hz) (1uHz - 50MHz).
PULSFALL
Sets the pulse waveform negative edge to <nrf> micro seconds. (Lower limit: 5ns - Upper limit: 99.9ns).
- FLOAT Fall
Sets the pulse waveform negative edge in micro seconds (5ns - 99.9ns).
DCOFFS
Sets the dc offset to <nrf> Volts. (Lower limit: -4.500 Vdc - Upper limit: 4.500 Vdc).
- FLOAT DCOffset
Sets the dc offset in Volts(Vdc) (4.500 Vdc - 4.500 Vdc).
PRE
Sets the Parallel Port Enable Register to the value <nrf>.
- BYTE Status
Set register value 0-255
CALIBRATION
Sets the calibration mode to <START>, <SAVE>, or <ABORT>. <nrf> represents the calibration password.
- BYTE Mode
0 = START, 1 = SAVE, 2 = ABORT
- ULONG Password
Calibration password
SWPMKRFREQ
Sets the sweep marker to <nrf> Hz. (Lower limit: 10kHz - Upper limit: 100kHz).
- FLOAT Frequency
Set the sweep marker in Hertz(Hz) (10kHz - 100kHz).
MODAMSRC
Sets AM waveform source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets AM waveform source (0 = INT, 1 = EXT).
AMPUNIT
Sets the amplitude units to; 0 = VPP, 1 = VRMS, 2 = DBM.
- BYTE Units
Sets the amplitude units (0 = VPP, 1 = VRMS, 2 = DBM).
ESRRet
Returns the value in the standard event status register in <nr1>
QERRet
Query and clear error register
SWPTIME
Sets the sweep time to <nrf> seconds
- FLOAT Seconds
Set the sweep time in seconds.
MODHOPFREQ
Sets HOP frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets HOP frequency in Hertz(Hz) (1uHz - 50MHz).
PULSWID
Sets the pulse waveform width to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
- FLOAT Seconds
Sets the pulse waveform width in seconds (20ns - 1Ms).
PRERet
Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
AMPL
Sets the amplitde to <nrf> in the units as specified by the AMPUNIT command. (Range = 10mVpp - 10Vpp)
- FLOAT Amplitude
Sets the amplitude (10mVpp - 10Vpp). Units specificied by AMPUNIT command.
MODPOLFSK
Sets FSK trigger slope to; 0 = POS, 1 = NEG.
- BOOL Slope
Set FSK trigger slope (0 = POS, 1 = NEG).
PULSEDGE
Sets the pulse waveform edges (positive and negative edge) to <nrf> micro Sec. Value zero sets to the minimum value allowed (Lower limit: 5ns - Upper limit: 40us).
- FLOAT Edges
Sets the pulse waveform edges in micro seconds (5ns - 40us).
ARB4Ret
ARBLOAD
<cpd> sets the output waveform type to <DC>,<SINC>, <EXPRISE>,<LOGRISE>,<RAMPUP>,<RAMPDN>, <TRIANG>,<SQUARE>, <ARB1>,<ARB2>,<ARB3>, <ARB4>, <"USERNAME1">, <"USERNAME2">, <"USERNAME3">, <"USERNAME4">.
- STRING Type
Waveform Type
ESERet
Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
SLVRST
Sets the SLAVE generator ready to be synchronised
SQRSYMM
Sets the square waveform symmetry to <nrf> %. (Lower limit: 20 - Upper limit: 80)
- FLOAT Symmetry
Sets the square waveform symmetry in percent (20 - 80).
OUTPUT
Sets the output to; 0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT.
- BYTE SetOutput
Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT).
MODPWMDEVWDT
Sets the PWM waveform deviation to <nrf> sec.
- FLOAT Sec
SWPMODE
Sets the sweep mode to <CONT> or <TRIG>. 0 = CONT, 1 = TRIG.
- BOOL Mode
Set the sweep mode (0 = CONT, 1 = TRIG).
MODFSKRATE
Sets FSK rate to <nrf> Hz. (Lower limit: 2mHz - Upper limit: 100kHz).
- FLOAT Rate
Sets FSK rate in Hertz(Hz) (2mHz - 100kHz).
BST
Sets the burst mode to; 0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>.
- BYTE MODE
Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE).
SYNCTYPE
Sets the sync type to; 0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER.
- BYTE Type
Set the sync type (0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER).
MODPWMSHAPE
Sets PWM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PWM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
LOLVL
Sets the amplitude-low-level to <nrf> Volts. (Lower limit: 5.000 V - Upper limit: -0.010 V).
- FLOAT LowLevel
Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V).
SAV
Saves the complete instrument setup to the setup-file named <nrf>
- BYTE StoreLocation
Memory location of register (0-9)
TRG
This command is the same as pressing the TRIGGER key.
ARBDCOFFS
Sets the arbritary dc waveform offset to <nrf> volts.
- FLOAT OffsetVoltage
Set the offset voltage
SWPTRGPOL
Sets the sweep trigger slope to; 0 = POS, 1 = NEG.
- BOOL Slope
Set the sweep trigger slope (0 = POS, 1 = NEG).
PULSRISE
- FLOAT Rise
Sets the pulse waveform positive edge in micro seconds (5ns - 99.9ns).
MODAMSHAPE
Sets AM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets AM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
CLKSRC
Sets the clock source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets the clock source (0 = INT, 1 = EXT).
ARB1DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1.
- STRING Return
BEEP
Sound one beep.
SWPCNTFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz).
SWP
Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF.
- BOOL Sweep
Enable or disable the sweep (0 = ON, 1 = OFF).
BSTTRGSRC
Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
- BYTE Source
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN).
MODPWMFREQ
Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ARB2Ret
RST
Resets the instrument parameters to their default values.
RMPSYMM
Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
- FLOAT Symmetry
Sets the ramp waveform symmetry in percent (0 - 100).
BSTCOUNT
Sets the burst count to <nrf> cycles, maximum 1048575 cycles.
- LONG Count
Sets the burst count in cycles (1 - 1048575).
SWPMKR
Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF.
- BOOL Marker
Enable or disable the sweep marker (0 = ON, 1 = OFF).
PULSFREQ
Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz).
- FLOAT Frequency
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz).
MODFMDEV
Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz).
- FLOAT Deviation
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz).
RCL
Recalls the instrument setup contained in store <nrf>.
Memory location (0-9)
ESESet
Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255)
- BYTE Value
Enable the register to this value. (0 - 255)
LOCAL
Returns the instrument to local opertion and unlocks the keyboard.
SWPSPNFREQ
Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz).
- FLOAT Frequency
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz).
CALSTEP
Step to the next calibration point.
OPC
Sets the Operation Complete bit (bit 0) in the Standard Event Status Register. This will happen immediately the command is executed because of the sequential nature of all operations.
SRERet
Returns the value of the Service Request Enable Register in <nr1> numeric format.
MODPMFREQ
Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
ARBRESIZE
Changes the size of arbritary waveform <cpd> to <nrf>.
- FLOAT Size
Size of waveform
- STRING Waveform
Arbritary Waveform
LRN
Intall data from a previous *LRN? command.
MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
- BYTE Shape
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
ARB4
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
- BYTE Waveform
CLKSRRet
Returns the clock source <INT> or <EXT>.
- BOOL Return
MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
- FLOAT Degrees
Sets PM waveform deviation in degrees (-360 - 360).
MSTLOCK
Sends signal to SLAVE generator to get synchronised
HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
- FLOAT HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
ARB3
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
- UINT Waveform
WAVE
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
- BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
- FLOAT Calibrate
Adjust the selected calibration value (-100 - 100).
STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
ARB2
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
- UINT Waveform
EERRet
Query and clear execution error number register.
- STRING Return
MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
- BOOL Source
Sets FM waveform source (0 = INT, 1 = EXT).
MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
- FLOAT Frequency
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
ESE
Sets the Standard Event Status Enable Register to the value of <nrf>.
- BYTE Value
Value of register 0-255
ARB1
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
- UINT Waveform
16 Bit binary number for arbitrary waveform.
ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
- STRING Return
CLS
Clears status byte register of the interface.
MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
- BYTE Percent
Sets the output noise level in percent. (0 - 50)
LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
- BYTE Mode
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
ADDRESSRet
Returns the instruments address
- INT Return
MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
- BOOL Source
Sets PM waveform source (0 = INT, 1 = EXT).
MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
- BOOL Source
Sets PWM waveform source (0 = INT, 1 = EXT).
MOD
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
- BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
- BOOL Return
LRNRet
Returns the complete setup of the instrument as a binary data block
- INT Return
OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
- BOOL Return
SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
- BYTE Type
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
- BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
- BOOL Return
BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
- BOOL Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
ARB3Ret
BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
- FLOAT Degrees
Sets the burst phase in degrees (-360 - 360)
IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
- STRING ReturnIDN
- STRING Return
SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
- FLOAT Seconds
Set the sweep trigger period in seconds.
PULSDLY
Sets the waveform delay to <nrf> sec
- FLOAT Sec
COM Port
Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
NOISADD
- BOOL Noise
PULSSYMM
- FLOAT Symmetry
BSTPER
- FLOAT Seconds
MODAMDEPTH
- FLOAT Frequency
WAI
SWPBEGFREQ
- FLOAT Frequency
MODFMFREQ
- FLOAT Frequency
MODFSKSRC
- BOOL Source
MODPWMDEVSYM
- BYTE Deviation
ARB3DEFRet
- STRING Return
PER
- FLOAT Period
BEEPMODE
- BYTE Mode
SWPTRGSRC
- BYTE Source
PULSPER
- FLOAT Period
ARBDEF
- STRING Name
- STRING State
- STRING Location
WAVELVL
- FLOAT Percent
CALVALRet
SWPENDFREQ
- FLOAT Frequency
ZLOAD
- INT Output
MODFMSHAPE
- BYTE Shape
AMPLRNG
- BOOL Range
SYNCOUT
- BOOL Sync
SRE
- BYTE Status
ARB1Ret
ARB2DEFRet
- STRING Return
FREQ
- FLOAT Frequency
PULSFALL
- FLOAT Fall
DCOFFS
- FLOAT DCOffset
PRE
- BYTE Status
CALIBRATION
- BYTE Mode
- ULONG Password
SWPMKRFREQ
- FLOAT Frequency
MODAMSRC
- BOOL Source
AMPUNIT
- BYTE Units
ESRRet
QERRet
SWPTIME
- FLOAT Seconds
MODHOPFREQ
- FLOAT Frequency
PULSWID
- FLOAT Seconds
PRERet
AMPL
- FLOAT Amplitude
MODPOLFSK
- BOOL Slope
PULSEDGE
- FLOAT Edges
ARB4Ret
ARBLOAD
- STRING Type
Waveform Type
ESERet
SLVRST
SQRSYMM
- FLOAT Symmetry
OUTPUT
- BYTE SetOutput
MODPWMDEVWDT
- FLOAT Sec
SWPMODE
- BOOL Mode
MODFSKRATE
- FLOAT Rate
BST
- BYTE MODE
SYNCTYPE
- BYTE Type
MODPWMSHAPE
- BYTE Shape
LOLVL
- FLOAT LowLevel
SAV
TRG
ARBDCOFFS
SWPTRGPOL
- BOOL Slope
PULSRISE
- FLOAT Rise
MODAMSHAPE
- BYTE Shape
CLKSRC
- BOOL Source
ARB1DEFRet
- STRING Return
BEEP
Sound one beep.
SWPCNTFREQ
- FLOAT Frequency
SWP
- BOOL Sweep
BSTTRGSRC
- BYTE Source
MODPWMFREQ
- FLOAT Frequency
ARB2Ret
RST
RMPSYMM
- FLOAT Symmetry
BSTCOUNT
- LONG Count
SWPMKR
- BOOL Marker
PULSFREQ
- FLOAT Frequency
MODFMDEV
- FLOAT Deviation
RCL
ESESet
- BYTE Value
LOCAL
SWPSPNFREQ
- FLOAT Frequency
CALSTEP
OPC
SRERet
MODPMFREQ
- FLOAT Frequency
ARBRESIZE
- FLOAT Size
Size of waveform
- STRING Waveform
Arbritary Waveform
LRN
MODPMSHAPE
- BYTE Shape
ARB4
- BYTE Waveform
CLKSRRet
- BOOL Return
MODPMDEV
- FLOAT Degrees
MSTLOCK
HILVL
- FLOAT HighLevel
ARB3
- UINT Waveform
WAVE
- BYTE WaveType
CALADJ
- FLOAT Calibrate
STBRet
ARB2
- UINT Waveform
EERRet
- STRING Return
MODFMSRC
- BOOL Source
MODAMFREQ
- FLOAT Frequency
ESE
- BYTE Value
ARB1
- UINT Waveform
ARB4DEFRet
- STRING Return
CLS
MSTRELOCK
NOISLVL
- BYTE Percent
LOCKMODE
- BYTE Mode
ADDRESSRet
- INT Return
MODPMSRC
- BOOL Source
MODPWMSRC
- BOOL Source
MOD
- BYTE Modulation
ISTRet
- BOOL Return
LRNRet
- INT Return
OPCRet
- BOOL Return
SWPTYPE
- BYTE Type
PULSRANGE
- BYTE Range
TSTRet
- BOOL Return
BSTTRGPOL
- BOOL Slope
ARB3Ret
BSTPHASE
- FLOAT Degrees
IDNRet
- STRING ReturnIDN
- STRING Return
SWPTRGPER
- FLOAT Seconds
PULSDLY
- FLOAT Sec
COM Port
Refresh COM Ports
NOISADD
- BOOL Noise
PULSSYMM
- FLOAT Symmetry
BSTPER
- FLOAT Seconds
MODAMDEPTH
- FLOAT Frequency
WAI
SWPBEGFREQ
- FLOAT Frequency
MODFMFREQ
- FLOAT Frequency
MODFSKSRC
- BOOL Source
MODPWMDEVSYM
- BYTE Deviation
ARB3DEFRet
- STRING Return
PER
- FLOAT Period
BEEPMODE
- BYTE Mode
SWPTRGSRC
- BYTE Source
PULSPER
- FLOAT Period
ARBDEF
- STRING Name
- STRING State
- STRING Location
WAVELVL
- FLOAT Percent
CALVALRet
SWPENDFREQ
- FLOAT Frequency
ZLOAD
- INT Output
MODFMSHAPE
- BYTE Shape
AMPLRNG
- BOOL Range
SYNCOUT
- BOOL Sync
SRE
- BYTE Status
ARB1Ret
ARB2DEFRet
- STRING Return
FREQ
- FLOAT Frequency
PULSFALL
- FLOAT Fall
DCOFFS
- FLOAT DCOffset
PRE
- BYTE Status
CALIBRATION
- BYTE Mode
- ULONG Password
SWPMKRFREQ
- FLOAT Frequency
MODAMSRC
- BOOL Source
AMPUNIT
- BYTE Units
ESRRet
QERRet
SWPTIME
- FLOAT Seconds
MODHOPFREQ
- FLOAT Frequency
PULSWID
- FLOAT Seconds
PRERet
AMPL
- FLOAT Amplitude
MODPOLFSK
- BOOL Slope
PULSEDGE
- FLOAT Edges
ARB4Ret
ARBLOAD
- STRING Type
Waveform Type
ESERet
SLVRST
SQRSYMM
- FLOAT Symmetry
OUTPUT
- BYTE SetOutput
MODPWMDEVWDT
- FLOAT Sec
SWPMODE
- BOOL Mode
MODFSKRATE
- FLOAT Rate
BST
- BYTE MODE
SYNCTYPE
- BYTE Type
MODPWMSHAPE
- BYTE Shape
LOLVL
- FLOAT LowLevel
SAV
TRG
ARBDCOFFS
SWPTRGPOL
- BOOL Slope
PULSRISE
- FLOAT Rise
MODAMSHAPE
- BYTE Shape
CLKSRC
- BOOL Source
ARB1DEFRet
- STRING Return
BEEP
Sound one beep.
SWPCNTFREQ
- FLOAT Frequency
SWP
- BOOL Sweep
BSTTRGSRC
- BYTE Source
MODPWMFREQ
- FLOAT Frequency
ARB2Ret
RST
RMPSYMM
- FLOAT Symmetry
BSTCOUNT
- LONG Count
SWPMKR
- BOOL Marker
PULSFREQ
- FLOAT Frequency
MODFMDEV
- FLOAT Deviation
RCL
ESESet
- BYTE Value
LOCAL
SWPSPNFREQ
- FLOAT Frequency
CALSTEP
OPC
SRERet
MODPMFREQ
- FLOAT Frequency
ARBRESIZE
- FLOAT Size
Size of waveform
- STRING Waveform
Arbritary Waveform
LRN
MODPMSHAPE
- BYTE Shape
ARB4
- BYTE Waveform
CLKSRRet
- BOOL Return
MODPMDEV
- FLOAT Degrees
MSTLOCK
HILVL
- FLOAT HighLevel
ARB3
- UINT Waveform
WAVE
- BYTE WaveType
CALADJ
- FLOAT Calibrate
STBRet
ARB2
- UINT Waveform
EERRet
- STRING Return
MODFMSRC
- BOOL Source
MODAMFREQ
- FLOAT Frequency
ESE
- BYTE Value
ARB1
- UINT Waveform
ARB4DEFRet
- STRING Return
CLS
MSTRELOCK
NOISLVL
- BYTE Percent
LOCKMODE
- BYTE Mode
ADDRESSRet
- INT Return
MODPMSRC
- BOOL Source
MODPWMSRC
- BOOL Source
MOD
- BYTE Modulation
ISTRet
- BOOL Return
LRNRet
- INT Return
OPCRet
- BOOL Return
SWPTYPE
- BYTE Type
PULSRANGE
- BYTE Range
TSTRet
- BOOL Return
BSTTRGPOL
- BOOL Slope
ARB3Ret
BSTPHASE
- FLOAT Degrees
IDNRet
- STRING ReturnIDN
- STRING Return
SWPTRGPER
- FLOAT Seconds
PULSDLY
- FLOAT Sec
COM Port
Refresh COM Ports
NOISADD
- BOOL Noise
PULSSYMM
- FLOAT Symmetry
BSTPER
- FLOAT Seconds
MODAMDEPTH
- FLOAT Frequency
WAI
SWPBEGFREQ
- FLOAT Frequency
MODFMFREQ
- FLOAT Frequency
MODFSKSRC
- BOOL Source
MODPWMDEVSYM
- BYTE Deviation
ARB3DEFRet
- STRING Return
PER
- FLOAT Period
BEEPMODE
- BYTE Mode
SWPTRGSRC
- BYTE Source
PULSPER
- FLOAT Period
ARBDEF
- STRING Name
- STRING State
- STRING Location
WAVELVL
- FLOAT Percent
CALVALRet
SWPENDFREQ
- FLOAT Frequency
ZLOAD
- INT Output
MODFMSHAPE
- BYTE Shape
AMPLRNG
- BOOL Range
SYNCOUT
- BOOL Sync
SRE
- BYTE Status
ARB1Ret
ARB2DEFRet
- STRING Return
FREQ
- FLOAT Frequency
PULSFALL
- FLOAT Fall
DCOFFS
- FLOAT DCOffset
PRE
- BYTE Status
CALIBRATION
- BYTE Mode
- ULONG Password
SWPMKRFREQ
- FLOAT Frequency
MODAMSRC
- BOOL Source
AMPUNIT
- BYTE Units
ESRRet
QERRet
SWPTIME
- FLOAT Seconds
MODHOPFREQ
- FLOAT Frequency
PULSWID
- FLOAT Seconds
PRERet
AMPL
- FLOAT Amplitude
MODPOLFSK
- BOOL Slope
PULSEDGE
- FLOAT Edges
ARB4Ret
ARBLOAD
- STRING Type
Waveform Type
ESERet
SLVRST
SQRSYMM
- FLOAT Symmetry
OUTPUT
- BYTE SetOutput
MODPWMDEVWDT
- FLOAT Sec
SWPMODE
- BOOL Mode
MODFSKRATE
- FLOAT Rate
BST
- BYTE MODE
SYNCTYPE
- BYTE Type
MODPWMSHAPE
- BYTE Shape
LOLVL
- FLOAT LowLevel
SAV
TRG
ARBDCOFFS
SWPTRGPOL
- BOOL Slope
PULSRISE
- FLOAT Rise
MODAMSHAPE
- BYTE Shape
CLKSRC
- BOOL Source
ARB1DEFRet
- STRING Return
BEEP
Sound one beep.
SWPCNTFREQ
- FLOAT Frequency
SWP
- BOOL Sweep
BSTTRGSRC
- BYTE Source
MODPWMFREQ
- FLOAT Frequency
ARB2Ret
RST
RMPSYMM
- FLOAT Symmetry
BSTCOUNT
- LONG Count
SWPMKR
- BOOL Marker
PULSFREQ
- FLOAT Frequency
MODFMDEV
- FLOAT Deviation
RCL
ESESet
- BYTE Value
LOCAL
SWPSPNFREQ
- FLOAT Frequency
CALSTEP
OPC
SRERet
MODPMFREQ
- FLOAT Frequency
ARBRESIZE
- FLOAT Size
Size of waveform
- STRING Waveform
Arbritary Waveform
LRN
MODPMSHAPE
- BYTE Shape
ARB4
- BYTE Waveform
CLKSRRet
- BOOL Return
MODPMDEV
- FLOAT Degrees
MSTLOCK
HILVL
- FLOAT HighLevel
ARB3
- UINT Waveform
WAVE
- BYTE WaveType
CALADJ
- FLOAT Calibrate
STBRet
ARB2
- UINT Waveform
EERRet
- STRING Return
MODFMSRC
- BOOL Source
MODAMFREQ
- FLOAT Frequency
ESE
- BYTE Value
ARB1
- UINT Waveform
ARB4DEFRet
- STRING Return
CLS
MSTRELOCK
NOISLVL
- BYTE Percent
LOCKMODE
- BYTE Mode
ADDRESSRet
- INT Return
MODPMSRC
- BOOL Source
MODPWMSRC
- BOOL Source
MOD
- BYTE Modulation
ISTRet
- BOOL Return
LRNRet
- INT Return
OPCRet
- BOOL Return
SWPTYPE
- BYTE Type
PULSRANGE
- BYTE Range
TSTRet
- BOOL Return
BSTTRGPOL
- BOOL Slope
ARB3Ret
BSTPHASE
- FLOAT Degrees
IDNRet
- STRING ReturnIDN
- STRING Return
SWPTRGPER
- FLOAT Seconds
PULSDLY
- FLOAT Sec
COM Port
Refresh COM Ports
