Component: Thermocouple (MCP960X) (Environmental)
| Version | 1.1 |
| Category | Environmental |
Thermocouple (MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Please click here to download the component source project: FC_Comp_Source_ThermocoupleMCP960X.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ThermocoupleMCP960X.fcfx
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
| ReadReference_Int | |
| Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
| ReadRawDataADC | |
| Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
| ReadReference_Float | |
| Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures. | |
| ReadThermocouple_Int | |
| Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
| ReadThermocouple_Float | |
| Returns the thermocouple temperature from the last sample as a floating point value. Use Sample first, which samples both reference & themocouple temperatures. | |
| Configures the I2C bus ready for communications. | |
| ReadRawDataADC | |
| ReadRawDataADC | |
| ReadRawDataADC | |
