Component: WLAN ESP32 (Dummy) (ESP32) (Comms: Networking)
Revision as of 10:00, 27 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.3
Category Comms: Networking
WLAN ESP32 (Dummy) component
Wireless LAN component designed to work with ESP32 modules
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP32_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP32_Dummy.fcfx
Here is an example Flowcode program to send analogue data to a html web page. The web page is set up to refresh every second Instructions on how to change the refresh rate and access the web page is explained within the example file. ESP Webpage
SocketConnect
- STRING Address
- UINT Port
SocketListen
Listen on, or bind, local port to already opened socket. Returns 1 if OK, 0 if fail
- UINT Port
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE Index
SSID Index
- STRING Return
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING SSID
Name of the wireless network to create
- STRING Password
Password used to gain access to the network
- BYTE Channel
802.11 Channel Range 1-14
- BYTE Encryption
0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
ReadIP
Collects the local IP address
- BYTE Index
SocketWrite
- STRING Buffer
- UINT Size
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE Index
SSID Index
- INT Return
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE Index
SSID Index
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING SSID
- STRING Key
- BYTE Timeout
Number of seconds to wait for the connection, default 20
SocketOpen
Returns 1 if socket sucessfully opened
SocketClose
AcceptOpen
Returns 1 if there is an incoming connection on the listening port
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
SocketRead
- STRING Buffer
- UINT Size
AcceptClose
Close the socket associated with the Accepted incoming connection
Initialise the WiFi system Returns 1 if successful Returns 0 if not
Simulation Method
Decides how to handle the simulation of the component. TCP Base - Allows simulation of the network communications using the TCP Base component and DLL. COM/Injector - Allows the simulation to connect to real hardware or injectors.
SocketConnect
- STRING Address
- UINT Port
SocketListen
- UINT Port
ReadSSIDFromScan
- BYTE Index
SSID Index
- STRING Return
CreateAccessPoint
- STRING SSID
- STRING Password
- BYTE Channel
- BYTE Encryption
ReadIP
- BYTE Index
SocketWrite
- STRING Buffer
- UINT Size
- BYTE Index
SSID Index
- INT Return
- BYTE Index
SSID Index
ConnectToSSID
- STRING SSID
- STRING Key
- BYTE Timeout
SocketOpen
SocketClose
AcceptOpen
ScanForSSID
SocketRead
- STRING Buffer
- UINT Size
AcceptClose
Simulation Method
SocketConnect
- STRING Address
- UINT Port
SocketListen
- UINT Port
ReadSSIDFromScan
- BYTE Index
SSID Index
- STRING Return
CreateAccessPoint
- STRING SSID
- STRING Password
- BYTE Channel
- BYTE Encryption
ReadIP
- BYTE Index
SocketWrite
- STRING Buffer
- UINT Size
- BYTE Index
SSID Index
- INT Return
- BYTE Index
SSID Index
ConnectToSSID
- STRING SSID
- STRING Key
- BYTE Timeout
SocketOpen
SocketClose
AcceptOpen
ScanForSSID
SocketRead
- STRING Buffer
- UINT Size
AcceptClose
Simulation Method
SocketConnect
- STRING Address
- UINT Port
SocketListen
- UINT Port
ReadSSIDFromScan
- BYTE Index
SSID Index
- STRING Return
CreateAccessPoint
- STRING SSID
- STRING Password
- BYTE Channel
- BYTE Encryption
ReadIP
- BYTE Index
SocketWrite
- STRING Buffer
- UINT Size
- BYTE Index
SSID Index
- INT Return
- BYTE Index
SSID Index
ConnectToSSID
- STRING SSID
- STRING Key
- BYTE Timeout
SocketOpen
SocketClose
AcceptOpen
ScanForSSID
SocketRead
- STRING Buffer
- UINT Size
AcceptClose
Simulation Method
