Component: LED Free (SMD, PCB) ()
Revision as of 10:01, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category
LED Free (SMD, PCB) component
Surface mount LED in standard PLCC2 package. Colour can be set friom component properties.
Please click here to download the component source project: FC_Comp_Source_led_plcc2_free.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_plcc2_free.fcfx
LED Resistor Calculator Tool
Connection
Pin to which the LED is connected.
Polarity
Active High: Pin true -> On color, Pin false -> Off color. Active Low: Pin true -> Off color, Pin false -> On color.
Color
Color to use when the LED is turned on. When turned off, uses a much darker shade of the same hue.
Show
Decide what labels to show... None - no labels are displayed Name - shows each component's name Property - shows a particular property of each component (see 'property' below.
Property
Show a particular property of each object. If a port or pin property is chosen, the label can be abbreviated to remove the '$PORT' text.
Color
Color of the labels text.
Scale
Sets the basic size (text height) of the labels.
Follow Zoom
Whether labels get bigger and smaller when the panel is zoomed in and out.
Position
Position of the label relative to the component
Connection
Polarity
Color
Show
Property
Color
Scale
Follow Zoom
Position
Connection
Polarity
Color
Show
Property
Color
Scale
Follow Zoom
Position
Connection
Polarity
Color
Show
Property
Color
Scale
Follow Zoom
Position
