Component: Motor Template (Mechatronics)
Revision as of 10:01, 27 January 2023 by Wiki bot (talk | contribs)
Version 1.1
Category Mechatronics
Motor Template component
Base component for constructing continuous motion - e.g. motors. Automatically animates two objects - one within the same host components (e.g. moving parts of the motor itself), and one external (e.g. the mechanism to which the motor is connected).
Please click here to download the component source project: FC_Comp_Source_motor_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_motor_base.fcfx
Simple example showing how to drive the motor components and how to create sub assemblies attached to the motor output shafts in the simulation panels. FC6 Icon.png Motors
Fc9-comp-macro.png SetTarget
Set a target object external to the motor component. This allows the motor to link "mechanically" to other components and move them around.
Fc9-h32-icon.png - HANDLE Target
The object to set as a target
Fc9-comp-macro.png SetSpeed
Sets the speed for all attached objects. The speed will change at the rate set by the acceleration property.
Fc9-f32-icon.png - FLOAT Speed
World units or degrees per second.
Fc9-conn-icon.png Animation
Fc9-type-21-icon.png Frame Interval
Time interval between animation frames. Does not affect the speed of motion, only the rate of screen updates.
Fc9-type-16-icon.png On Stop
Decide what action to take when simulation stops. No Action - Animation is paused, continues from this position when simulation restarts Return to start - all object returned to their start positions, current speed resumes on simulation start. Clear speeds - objects retain their position, but speed is set to zero. Return and clear - objects return to start position and have theri speed set to zero.
Fc9-conn-icon.png Moving Part
Fc9-type-17-icon.png Target Object
An object within the same host component which the motor will animate.
Fc9-type-17-icon.png Axis Object
If the motion property is set to 'Rotary', this sets an object around which the rotation will happen. If not set, the 'Target' object will rotate around its own centre.
Fc9-type-16-icon.png Axis
Which axis to move along or around.
Fc9-type-16-icon.png Motion
The kind of motion to animate. Rotary - animated targets will rotate around the given axis. Linear - animated object will move in a straight line. Note that there is nothing to prevent the object from moving off screen - stopping or reversing the motion is controlled only by the macro calls.
Fc9-type-15-icon.png Acceleration
Amount of speed change allowed per second when the motor is powered. Set to zero for instantaneous speed changes.
Fc9-type-15-icon.png Deceleration
Amount of speed change allowed per second when power is removed and the motor is coasting. Set to zero for instantaneous speed changes.
