| Author
Matrix Ltd
| Version
1.3
| Category
Controls
Simulation Switch Template component
A base for building switches that do not download to chip. Mouse interaction can send 'System.User' events with the following data... ID = The handle of the switch component sending the message Message = 1 (on) or 0 (off) Current state can also be read via simulation macros.
Please click here to download the component source project: FC_Comp_Source_sim_switch_base.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sim_switch_base.fcfx
GetState
| Read the current state of the switch. Returns BOOL true when the switch is on, or BOOL false when off.
- BOOL
SetState
| Sets the current state of the switch. BOOL true when the switch is on, or BOOL false when off.
- BOOL
SwitchState
| Sets the state of the switch
Operation
| Latching = Mouse click to turn on, click again to turn off. Momentary = Mouse click to turn on, release to turn off.
Send Event
| Determine when the component will send a User event to its parent. On Change - Whenever the switch state changes. On Click - Only when the mouse clicks the object. On Release - Only when the mouse is released over the object. Never - No events.
Moving part
| Handle of a panel object that will be the moving part of the switch.
Pivot object
| Object around which the moving part will rotate when rotation is selected as the movement tyoe.
Type
| Set whether the moving part will move linearly or by rotation.
Axis
| Axis along which the moving part will move (for push/slide) or around which it will rotate (rotary).
Movement
| Distance or angle by which the mioving part will move.
Show
| Decide what label to show... None - no labels are displayed Name - shows the component's name Property - shows a property value of the component (a field for the property name will appear below)
Startup State
| Default state of the indicator when loading the project or starting the simulation runtime.
GetState
- BOOL
SetState
- BOOL
SwitchState
Operation
Send Event
Moving part
Pivot object
Type
Axis
Movement
Show
Startup State
GetState
- BOOL
SetState
- BOOL
SwitchState
Operation
Send Event
Moving part
Pivot object
Type
Axis
Movement
Show
Startup State
GetState
- BOOL
SetState
- BOOL
SwitchState
Operation
Send Event
Moving part
Pivot object
Type
Axis
Movement
Show
Startup State
