Author
Matrix Ltd
Version
1.1
Category
Switch (Push, PCB) component
Simple tactile PCB switch for PCB mounting. Approx. 12 * 12mm. Color and operation can be set from properties.
Please click here to download the component source project: FC_Comp_Source_sw_push_pcb.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_sw_push_pcb.fcfx
Switch
(5V / 11K) * 10K = 4.54545V
Connection
The chip pin to which the switch connects.
Polarity
Set the polarity of states sent to the chip pin. 'Active High' -> Pressed = On, Released = Off 'Active Low' -> Pressed = Off, Released = On
Debounce (ms)
Sets the time in milliseconds to allow a pin change to settle into a stable state. NB) Debouncing is only used when reading the button state using the component macros. Chip pins are NOT debounced.
Operation
Latching = Mouse click to turn on, click again to trun off. Momentary = Click to turn on, release to turn off.
Color
Color of the key cap
Connection
Polarity
Debounce (ms)
Operation
Color
Connection
Polarity
Debounce (ms)
Operation
Color
Connection
Polarity
Debounce (ms)
Operation
Color
