Component: 7Segment (74HC595) (Segment)
Revision as of 16:46, 30 January 2023 by Wiki bot (talk | contribs)
Category Segment
7Segment (74HC595) component
Seven segment display using 74HC595 serial to parallel shift register. Requires three standard output pins to drive the shift register. Shift registers can be chained together to drive up to six individual 7-segment displays.
Please click here to download the component source project: FC_Comp_Source_74HC595_7SEG_Hex_Driver.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_74HC595_7SEG_Hex_Driver.fcfx
ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
- BYTE Value0
The number value to set the digit to (0...15), 16=Clear
- BYTE Value1
- BYTE Value2
- BYTE Value3
- BYTE Value4
- BYTE Value5
- BYTE DecimalPoint
Bit field containing the states of the decimal points.
ShowSegments
Allows for manual control over the display segments. The colon character can also be controlled when writing to digit 1.
- BYTE Digit
Which of the digits to change. (0...5)
- BYTE Segments
The binary segment value to display, 0b1 = Lit, 0b0 = Not Lit
ShowDigit
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE Digit
- BYTE Value
- BYTE DecimalPoint
Whether to show the decimal point.
Number 7Segs
Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
Show segment name labels overlayed over the component.
Data Pin
Data Pin connection to the first 74HC595 chip
Clock Pin
Clock Pin connection to all the 74HC595 chips
Latch Pin
Latch Pin connection to all the 74HC595 chips
Colors
LED Color
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Color
Color of the plastic casing containing the LEDs.
Label Color
Color for the optional LED segment labels.
