| Author
Matrix Ltd
| Version
2.10
| Category
Comms: Interface
CAN (Internal, MCP2515) component
Low level routines for controling the CAN interface either using an external MCP2515 IC and a SPI bus connection or using an internal CAN peripheral if available on your device. Both methods will require a CAN driver IC like the MCP2551 to drive the CAN signals on the bus.
Please click here to download the component source project: FC_Comp_Source_CAN.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CAN.fcfx
ReadSwitches
| Returns switch input states from the external MCP2515 device. 0 = No Switch Pressed, 1 = Switch 1 Pressed, 2 = Switch 2 Pressed, 3 = Both Pressed (External CAN only)
- BYTE
SetTxData
| Assigns one of the outgoing transmit buffers with data ready to be sent.
- BYTE
Buffer
- BYTE
Count
- BYTE
d0
- BYTE
d1
- BYTE
d2
- BYTE
d3
- BYTE
d4
- BYTE
d5
- BYTE
d6
- BYTE
d7
SetRxMask
| Allows the receive ID mask to be configured on the fly allowing different ID ranges to be received.
- BYTE
Mask
| Specifies which receive mask to modify. Range: 0-1
- ULONG
ID
| The ID mask value you wish to use
GetRxData
| Returns last received message data byte at position Index. Buffer parameter is currently ignored
- BYTE
Buffer
- BYTE
Index
- BYTE
GetRxIDHi
| Gets the Hi byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE
Buffer
| Receive Buffer. Range 0-1
- BYTE
SetTxIDSimple
| Set the Tx CAN ID as a generic number. Standard IDs only 0-2047.
- BYTE
Buffer
| Transmit buffer to load. Range: 0-2
- UINT
ID
| The ID value you wish to use. Range: 0-2047
SendBuffer
| Transmits one of the transmit buffers which should have already been populated with an ID and data.
- BYTE
Buffer
| Specifies which transmit buffer to send
GetRxDataCount
| Returns last received message data length. Buffer parameter is currently ignored
- BYTE
Buffer
- BYTE
SetRxFilterID
| sets the Filter Standard mode only (for V5 compatibility only)
- BYTE
Filter
| Specifies which filter to modify. Range: 0-5
- BYTE
| ID bits 3-10
- BYTE
Lo
| ID bits 0-2 stored in the upper 3 bits of the byte
GetRxIDLo
| Gets the Lo byte Rx ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE
Buffer
- BYTE
SetRxMaskID
| set the Mask Standard ID mode only (for V5 compatibility)
- BYTE
Mask
- BYTE
| ID bits 3-10
- BYTE
Lo
SetRxFilter
| Allows the receive ID filter to be configured on the fly allowing different ID ranges to be received.
- BYTE
Filter
| Specifies which receive filter to modify. Range: 0-5
- ULONG
ID
| The ID filter value you wish to use
SetTxIdent
| Set the Tx CAN ID as a generic number. Standard and extended IDs Standard 0-2047 Extended 2048-536870911
- BYTE
Buffer
- ULONG
ID
| The ID or Extended ID value you wish to use. Range: 0-536870911
CheckRx
| Checks to see if any messages are available for 'Buffer' specified
- BYTE
Buffer
| Send buffer: 0 to 1
- BYTE
ChangeRate
| Simple attempt to alter the bus rate of the CAN. External CAN channels only,
- BYTE
Rate
| Rate: 0-3 where 0=125, 1=250, 2=500, 3=1000
GetRxIDSimple
| Gets the Rx ID as a Integer Standard ID only 0-2047.
- BYTE
Buffer
- UINT
SetTxID
| Set the Tx CAN ID in register format. Standard ID only 0-2047. Compatible with v5 component and previous,
- BYTE
Buffer
- BYTE
| ID bits 3-10 e.g. ((ID & 0x7F8) >> 3)
- BYTE
Lo
| ID bits 0-2 stored in the upper 3 bits of the byte e.g. ((ID & 0x7) << 5)
ShowLEDs
| Set LED state (External CAN only)
- BYTE
led1
| Controls LED 1. Range: 0-1
- BYTE
led2
| Controls LED 2. Range: 0-1
GetRxIdent
| Gets the Rx ID as a Integer Standard and Extended IDs.
- BYTE
Buffer
- ULONG
| Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
| Switches between Internal CAN peripheral and External CAN controller IC MCP2515.
Controller Osc
Bus Rate
| Data rate of the bus specified in thousand bits per second, Kbps.
Sync Jump Width
| Defines how far a resyncronisation may move the sample point
Sample Point
| Point in each bit period where the incoming data is sampled.
ID Type
| Switches between using Standard, or Standard and Extended CAN
One Shot Mode
| Disabled. Messages will reattempt transmission Enabled. Message will only attempt to transmit once
SPI
CHANNEL
| SPI Channel selector
MOSI
MISO
CLK
SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Prescale
| Prescale option selector
Sample Point
| Data bit read sample point
Config Delay
TX Buffer 0
Message ID
| TX Buffer 0 Message Identifier
Length
| TX Buffer 0 Number of data bytes
D0
| TX Buffer 0 Data Byte 0
D1
| TX Buffer 0 Data Byte 1
D2
| TX Buffer 0 Data Byte 2
D3
| TX Buffer 0 Data Byte 3
D4
| TX Buffer 0 Data Byte 4
D5
| TX Buffer 0 Data Byte 5
D6
| TX Buffer 0 Data Byte 6
D7
| TX Buffer 0 Data Byte 7
TX Buffer 1
Message ID
| TX Buffer 1 Message Identifier
Length
| TX Buffer 1 Number of data bytes
D0
| TX Buffer 1 Data Byte 0
D1
| TX Buffer 1 Data Byte 1
D2
| TX Buffer 1 Data Byte 2
D3
| TX Buffer 1 Data Byte 3
D4
| TX Buffer 1 Data Byte 4
D5
| TX Buffer 1 Data Byte 5
D6
| TX Buffer 1 Data Byte 6
D7
| TX Buffer 1 Data Byte 7
TX Buffer 2
Message ID
| TX Buffer 2 Message Identifier
Length
| TX Buffer 2 Number of data bytes
D0
| TX Buffer 2 Data Byte 0
D1
| TX Buffer 2 Data Byte 1
D2
| TX Buffer 2 Data Byte 2
D3
| TX Buffer 2 Data Byte 3
D4
| TX Buffer 2 Data Byte 4
D5
| TX Buffer 2 Data Byte 5
D6
| TX Buffer 2 Data Byte 6
D7
| TX Buffer 2 Data Byte 7
RX Buffer 0
Settings
| RX Buffer 0 Message Receive Mode
RX Buffer 1
Settings
| RX Buffer 1 Message Receive Mode
| Comms Flasher Identification Label
Simulate SPI Comms
