| Author
Matrix Ltd
| Version
3.0
| Category
Runtime Tools
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
Auto Detect Example
ReceiveByte
| Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property.
- UINT
Timeout
| Time to wait for incoming data in milliseconds
- UINT
ConfigureConsole
- BYTE
Status
SendString
| Sends an string of characters to the COM port.
- STRING
Data
| Data byte array to send
ReceiveINTArray
| Receives an array of 16-bit INT/UINT values and returns the number of values received.
- UINT
Data
| Array to store the incoming data
- BYTE
NumValues
| Maximum number of values to try and receive
- BOOL
MSBfirst
| 0=Least significant byte first, 1=Most significant byte first
- BYTE
Timeout
| Max amount of time in ms to wait between bytes
- BYTE
ReceiveNumber
| Attempts to receive a number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
| Max time in ms to wait in between bytes
- BOOL
IgnoreData
| 0=Dont ignore any data, 1=Ignore any initial none numeric data
- LONG
SendBinary16Bit
| Sends out a 16-bit binary value split across two bytes.
- UINT
Value
- BOOL
MSBfirst
SendINTArray
| Transmits an array of 16-bit INT/UINT values via the UART peripheral
- UINT
Data
| Data to transmit
- BYTE
NumValues
| Number of 16-bit values to send from the array
- BOOL
MSBfirst
SendNumber
| Sends out a number as an ASCII String from the UART interface.
- LONG
Number
ReceiveBinary32Bit
| Receives a binary 32-bit value split across four bytes.
- BOOL
MSBfirst
- BYTE
Timeout
- ULONG
ClosePort
| Closes the currently open COM port, ending communications and allowing it to be accessed via another application.
ReceiveBinaryFloat
| Receives a binary 32-bit floating point value split across four bytes.
- BOOL
MSBfirst
- BYTE
Timeout
- FLOAT
SendByte
| Sends a single byte to be sent out via the COM port.
- BYTE
Data
SetDTRState
| Allows the DTR signal to be enabled or disabled.
- BYTE
State
| A value of 0 disables the DTR, 1 or above willl enable the DTR.
ScanForDeviceID
| Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found.
- STRING
HWID
| Example: "VID_12BF&PID_0101"
- BYTE
GetConsoleHandle
| Gets the handle to the console allowing data displaying on the panel etc.
- HANDLE
SendByteArray
| Sends an array of bytes to the COM port.
- BYTE
Data
- UINT
Length
| Number of bytes to send
ReceiveBinary16Bit
| Receives a binary 16-bit value split across two bytes.
- BOOL
MSBfirst
- BYTE
Timeout
- UINT
ReceiveFloat
| Attempts to receive a floating point number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none numeric char is received, the none numeric char will be lost.
- BYTE
Timeout
- BOOL
IgnoreData
- FLOAT
SendFloat
| Sends out a floating point number as an ASCII String from the UART interface.
- FLOAT
Number
SendHexNumber
| Sends out a number as an ASCII hexadecimal String from the UART interface.
- ULONG
Number
- BYTE
NumChars
| Number of characters in the string data, 0 for auto, 2 for 0x00, 4 for 0x0000
- BOOL
Prefix
| Generate hexadecimal prefix 0x e.g. 1= 0xFF, 0= FF
SetFlowControl
| Allows the Flowcontrol signals to be enabled or disabled.
- BYTE
State
| A value of 0 disables flow control, 1 or above willl enable flow control.
OpenPort
| Opens the currently selected COM port, allowing data to be sent and received.
ReceiveHexNumber
| Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
- BYTE
Timeout
- BOOL
IgnoreData
- BOOL
Prefix
| Look for prefix before receiving, 1=0xFF, 0=FF
- ULONG
SetProp
| Allows the COM port property to be set from a parent component.
- STRING
PropName
- ULONG
PropVal
SendBinary32Bit
| Sends out a 32-bit binary value split across four bytes.
- ULONG
Value
- BOOL
MSBfirst
SendBinaryFloat
| Sends out a 32-bit binary floating point value split across four bytes.
- FLOAT
Value
- BOOL
MSBfirst
GetProp
| Allows the property filter for the COM port list to be copied to a parent component.
- STRING
PropName
- STRING
ReceiveByteArray
| Attempts to receive an array of bytes using the COM port Returns the number of bytes received.
- BYTE
Data
- UINT
MaxLength
| Max number of bytes to try and read
- UINT
Timeout
- UINT
ReceiveString
| Attempts to receive an string using the COM port Returns the number of bytes received.
- UINT
Timeout
- UINT
MaxLength
- STRING
COM Port
| Selects which port to communicate with, only lists ports which are currently available.
Refresh COM Ports
| When set to yes the COM port list is rescanned for newly connected or available ports. Note that refreshing the ports list may take a few seconds depending on the number of connected ports.
Baud
| Baud rate passed to the COM port to control the rate of data.
Timeout Value
| Value to specify what is returned when no incoming receive data is present.
Auto Close
| Auto close the port on Sim stop event
New Line Format
