Component: Input Digital Pin (DSP Inputs)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Version 1.2
Category DSP Inputs
Input Digital Pin component
Allows the values from a buffer to be assigned from a digital input pin. The input values for high and low state can be assigned using properties.
Please click here to download the component source project: FC_Comp_Source_DSP_InputPin.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DSP_InputPin.fcfx
SamplePin
Reads the value on the selected pin and based on the state outputs a value to the DSP buffer.
Buffer Size
Buffer Type
Sets the buffer data type, data is automatically scaled to fit and make full use of the data type.
Pin Connection
Pin which is sampled to provide the DSP input to the buffer.
High Value
Value to write to the buffer when the pin is in the high state.
Low Value
Value to write to the buffer when the pin is in the low state.
