Component: Gyroscope (EBM009) (EBM Modules)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Version 2.0
Category EBM Modules
Gyroscope component
Interface to the L3G4200D three axis digital gyroscope. Panel GUI can be used to simulate incoming data for testing.
Please click here to download the component source project: FC_Comp_Source_EBM009v1.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBM009v1.fcfx
Sample program demonstrating the EBM009 Gyroscope Sensor.
The program plots X, Y and Z data onto the LCD screen.
EBM009 Example
GetZ
Returns the previously sampled Z axis data
- INT Return
GetY
Returns the previously sampled Y axis data
- INT Return
GetX
Returns the previously sampled X axis data
- INT Return
SampleDevice
Reads the Axis data from the device. Returns 0 if successful
ReadRegister
Read the data byte at the given address of the device
- BYTE Reg
address of the register to be read
WriteRegister
Writes the data byte to the given address of the device. Returns 0 if successful
- BYTE Reg
address of register to be written with data byte
- BYTE data
data byte to be written to device register
Initialise the component. Returns 0 if successful
Output Data Rate
Full Scale Selection
Specifies the maximum angular speed which the sensor can measure in degrees per second
X Axis
Y Axis
Z Axis
Connection
Channel selection
SDA
SDA Remap Pin
SCL
SCL Remap Pin
Baud Select
Baud rate to be used
Stop Delay
Simulate Comms
