Component: Relay (BL0183) (E-blocks 2)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Relay (BL0183) component
The Relay is a digital normally open switch capable of switching much higher voltages and currents than your normal Microcontroller outputs. When set to HIGH, the LED will light up and the relay will close allowing current to flow. The peak voltage capability is 250V at 10 amps. Simulated component, green indiacator is on when the relay is active.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Relay_BL0183_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Relay_BL0183_2d.fcfx
Relay1SwitchOff
Switch off the relay, disconnecting the common pin from the normally open pin.
Relay2SwitchOff
Relay2SwitchOn
Switch on the relay, connecting the common pin to the normally open pin.
Relay1SwitchOn
Output Mode
Switch1
Port
Relay1 Pin
Relay2 Pin
