Component: Switch (BL0145) (E-blocks 2)
Revision as of 16:47, 30 January 2023 by Wiki bot (talk | contribs)
Category E-blocks 2
Switch component
A set of 8 push switches that can be connected to an E-blocks 2 upstream board via a port connector. Switches are wired in an active high configuration.
Please click here to download the component source project: FC_Comp_Source_EBlocks2_Switch_BL0145.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_EBlocks2_Switch_BL0145.fcfx
ReadState
Read the state of the switch at the given index.
- BYTE Index
The switch to read the status of.
- BOOL Return
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
WaitUntilLow
- BYTE Index
Input Mode
Choose how your switches are connected. PORT = Single port byte for all switches - pins are allocated in sequence from pin 0 - X Custom = Individual pin by pin connections
Port
