| Author
Matrix Ltd
| Version
1.6
| Category
Graphical Color
GLCD (ILI9163C) component
Graphical display component designed to work with the ILI9163C 16-bit colour graphical controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_ILI9163C.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ILI9163C.fcfx
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
BacklightOn
| Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
Plot
- UINT
X1
- UINT
Y1
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
FastPlot
| Sets a pixel with the current foreground colour at current pixel location. Not compatible with orientations other than 0.
SetDisplayOrientation
- BYTE
Orientation
BacklightOff
| Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
- UINT
X1
- UINT
Y1
Window
| Specifies a full screen or sub window of pixels to draw. Useful when used with the FastPlot function to draw bitmaps at high speed.
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
SetBackgroundColour
- BYTE
Red
| 0 - 255 where 0 = no red and 255 = maximum red
- BYTE
Green
| 0 - 255 where 0 = no green and 255 = maximum green
- BYTE
Blue
| 0 - 255 where 0 = no blue and 255 = maximum blue
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
Red
- BYTE
Green
- BYTE
Blue
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Offset X
Offset Y
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Data
| Data pin connection
Clock
| Clock pin connection
Chip Select
| Chip select pin connection
A0
| Instruction / Command pin connection
Reset
| Reset pin connection
LED
| LED backlight strobe pin connection
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
Component Label Scale
Physical Orientation
