Component: 4-Digit Display (Grove 104030003) 2D (104030003) (Segment)
Revision as of 16:48, 30 January 2023 by Wiki bot (talk | contribs)
Category Segment
4-Digit Display (Grove 104030003) 2D component
Quad seven segment display using an two pin communications bus to reduce the number of control pins. Based on the Grove module 104030003.
Please click here to download the component source project: FC_Comp_Source_Grove_4_Digit_Display_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Grove_4_Digit_Display_2dgi.fcfx
ShowDigits
Set the number and decimal point to be displayed in the given digit of the display.
- BYTE Value0
The number value to set the digit to (0...15), 16=Clear
- BYTE Value1
- BYTE Value2
- BYTE Value3
- BYTE Colon
Whether to show the colon character.
SetLEDs
Allows the individual LEDs for one of the segments to be set. The colon character can also be controlled when writing to digit 1.
- BYTE Digit
Which of the four digits to change. (0...3)
- BYTE Segments
The binary segment control value. 0=Clear, 1=Set
ShowDigit
Set the number to be displayed in the given digit of the display. The colon character can also be controlled when writing to digit 1.
- BYTE Digit
- BYTE Value
- BYTE Colon
Whether to show the colon character. Digit 1 only.
Display Type
Set this according to the specification of your hardware display. Common Anode: Pin true -> LED Off, Pin false -> LED On Common Cathode: Pin true -> LED On, Pin false -> LED Off
Show Seg Labels
Show segment name labels overlayed over the component.
DIO
Data Pin connection to TM1637 IC
CLK
Clock Pin connection to TM1637 IC
Colours
LED Colour
Color of the LED segments when truned on. When off, they use a much darker shade of the same hue.
Body Colour
Color of the plastic casing containing the LEDs.
Label Colour
Color for the optional LED segment labels.
