Selecting Compiler Options (ARM)
Allows users to set the Compiler options.
Options list
See the Managing Compiler Settings topic for more information on using this feature.
Substitute variables used by Flowcode
%T Target name as written e.g. AT91SAM7S128
(generally used by the compiler)
%t Target name forced to lower-case
%p Target name forced to upper-case
%a Alternative target name as written e.g. m32
(generally used by the programmer)
%A Alternative target name forced to upper-case
%f Long file name without extension e.g. C:\Development\Flowcode\TestProgram.fcf becomes:
- TestProgram
%F Short filename without extension e.g. C:\Development\Flowcode\TestProgram.fcf becomes:
- TestPr~1
%d Long file path for the Flowcode file e.g. C:\Development\Flowcode\TestProgram.fcf becomes:
%D Short file path for the Flowcode file C:\Development\Flowcode\TestProgram.fcf becomes:
C:\Develo~1\Flowcode
%c0 Configuration byte count
%c1 Configuration byte #1
%c2 Configuration byte #2
%c3 Configuration byte #3
Compiler location
Sets the location of the file controlling compilation
Default:
C:\Program Files\Matrix Multimedia\Flowcode_ARM\Tools\MX_bats\arm7comp.bat
Compiler parameters
Adds command line parameters when called from Flowcode
Default:
"%f" "%D"
Linker/Assembler location
Sets the location of the file controlling linking and assembly
Default:
C:\Program Files\Matrix Multimedia\Flowcode_ARM\Tools\MX_bats\arm7link.bat
Linker/Assembler parameters
Default:
"%f"
Programmer location
Sets the location of the file controlling the programming of the target device
Default:
C:\Program Files\Matrix Multimedia\Flowcode_ARM\Tools\mLoader.exe
Programmer parameters
Default:
"%f.bin"
Use programmer to set configuration options
This box should be left unchecked
Configuration parameters
This box should be left empty. Configuration parameters are set and downloaded from the Build->Configure menu.
Note: The above parameters assume you are using the AVRDUDE programming application and AVRISPmkII programmer. If you are using an alternative programming application or programmer you will need to consult the relevant documentation for the required parameters and settings.
File Viewer location
The default is empty, this activates the use of the internal C code viewer.
Default:
<empty>
File Viewer parameters
Default:
Blank. NO PARAMETERS.
