Component: Magnetometer (SM324) (Movement Orientation)
| Category | Movement Orientation |
Magnetometer (SM324) component
SM324 ultraprecise 24-bit smart magnetometer capable of distance measurement using a magnet. Controlled via I2C bus communications.
Please click here to download the component source project: FC_Comp_Source_Magnetometer_SM324.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Magnetometer_SM324.fcfx
| ReadStatus | |
| Reads the status byte from the sensor IC. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation | |
| WriteMemory | |
| Writes a 16-bit value to the specified memory location | |
| Address | |
| Internal memory address | |
| Value | |
| RequestData | |
| Requests temperature and magnetic data from the device, returns status. Bit 6 = Voltage OK Bit 5 = Busy Bit 2 = Memory Error Bit 0 = Saturation | |
| ReadTemperatureRaw | |
| Reads the temperature from the last succesful data read. | |
| ReadMagneticFieldRaw | |
| Reads the magnetic field from the last succesful data read. | |
| ReadMagneticFieldReal | |
| Reads the magnetic field from the last succesful data read as a float in Oersted Oe. | |
| WriteCommand | |
| Sends a command to the sensor IC. | |
| Command | |
| ReadTemperatureReal | |
| Reads the temperature from the last succesful data read as an float in degrees C. | |
| Sets up the I2C bus ready to communicate with the sensor IC. Sets the address variable back to the Address property value. | |
