Component: Temperature Sensor (Grove 101020015) (101020015) (Environmental)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Category Environmental
Temperature Sensor (Grove 101020015) component
Temperature Sensor uses a thermistor to measure ambient temperature. The resistance of thermistor changes based on ambient temperature. This resistance value alters the output of a voltage divider which is measured by an analog input pin and converted to a temperature value. The operating range is -40 to 125°C , with an accuracy of 1.5°C .
Please click here to download the component source project: FC_Comp_Source_TemperatureSensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TemperatureSensor.fcfx
GetTempInt
Reads the temperature of the temperature sensor and returns as an integer value.
- INT Return
GetTempFloat
Reads the temperature of the temperature sensor and returns as a floating point value.
- FLOAT Return
Tang Color
Colour of the moving part of the slider.
Marker Color
Colour of the marker line across the slider tang.
Settings
VRef voltage
VRef option
Conversion speed
Aquisition cycles
Bit Depth
