Component: PIC32 Core Timer (Timing)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Timing
PIC32 Core Timer component
Allows for easy and accurate timings using the built in Core timer on the PIC32 devices.
Please click here to download the component source project: FC_Comp_Source_TimerComponentPIC32Core.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TimerComponentPIC32Core.fcfx
Start_S
A none blocking function that allows for accurate delays to be specified in seconds using the core timer.
- ULONG Delay
Start_InstructionCount
A none blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer.
- ULONG Delay
Delay_S
A blocking function that allows for accurate delays to be specified in seconds using the core timer.
- ULONG Delay
Start_Ms
A none blocking function that allows for accurate delays to be specified in milliseconds using the core timer.
- ULONG Delay
Start_Us
A none blocking function that allows for accurate delays to be specified in micro seconds using the core timer.
- ULONG Delay
Delay_Ms
A blocking function that allows for accurate delays to be specified in milliseconds using the core timer.
- ULONG Delay
Delay_InstructionCount
A blocking function that allows for accurate delays to be specified in FOSC instructions using the core timer.
- ULONG Delay
Start_Ns
A none blocking function that allows for accurate delays to be specified in nano seconds using the core timer.
- ULONG Delay
Delay_Us
A blocking function that allows for accurate delays to be specified in micro seconds using the core timer.
- ULONG Delay
Delay_Ns
A blocking function that allows for accurate delays to be specified in nano seconds using the core timer.
- ULONG Delay
Check_Counter
Checks to see if the counter time is elapsed. Used in conjunction with the Start_ component macros. Returns 1 if complete or 0 if still counting.
- BOOL Return
