Component: WLAN Dummy (EB069, ESP8266) (ESP8266) (Wireless)
Revision as of 16:50, 30 January 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.0
Category Wireless
WLAN Dummy (EB069, ESP8266) component
Wireless LAN component designed to work with the ESP8266 module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the EB069 E-block.
Please click here to download the component source project: FC_Comp_Source_WLAN_ESP8266_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_WLAN_ESP8266_Dummy.fcfx
The examples below are all done using a EB091 board as the host
The EB069 ESP8266 Wifi E-block is connected to PORTD 0-7 with the patch setting set to B.
The EB005 LCD E-block is connected to PORTB 0-7 with the patch setting set to Default.
Other host boards are compatible with the examples, simply change the target chip and component connection properties.
Firmware Test
This example collects the firmware version from the ESP8266 module and displays it on an LCD. Tested working with firmware version 00150900.
FirmwareTest
Wireless Scanner
This example scans for wireless networks in range and prints the network IDs to the LCD along with the signal strength and security type.
WifiScan
Creating An Access Point
This example creates an access point you can connect your phone or laptop to named Flowcode_ESP8266. The password to connect to the access point is flowcode6.
Note this example simply creates an access point, no data is transferred.
CreateAP
Joining An Access Point
This example joins an existing access point. The network ID and Password must be altered to match your local WIFI network settings.
Note this example simply joins an access point, no data is transferred.
JoinAP
TCP Client
Once joined to the network the example connects to the MatrixTSL website and requests a file which is printed out on the LCD.
TCPClient
TCP Server
Once the access point is created the example shows the server IP address on the LCD. Connecting to the wireless network on your phone or laptop and visiting the IP address shown on the LCD using a web browser allows you to switch LED outputs on and off.
TCPServer
Network Comms
Here are some examples using the Network Communication component linked to the ESP8266 component.
NetworkComms ESP8266 Client
NetworkComms ESP8266 Webserver
SendString
Sends the given Text. Appends a CR to the end of the string it SendCR is greater than 0.
- STRING Text
- BYTE SendCR
DisconnectFromSSID
Disconnects from the current SSID. Returns 1 if the command was accepted and returned an "OK"
ClientConnect
Creates a TCP or UDP connection to a remote server. Returns the state of the connection. 0=Connection failed 1=Connection active
- BYTE Type
0 = TCP, 1 = UDP
- STRING IPAddress
e.g. "192.168.1.20"
- UINT Port
Remote port number to connect to, HTTP comms = Port 80
ControlTCPServer
Allows a TCP web page server to be switched on and off on the selected port. Returns 1 if the command was completed correctly.
- BYTE Enable
0 = Stop Server, 1 = Start Server
- UINT Port
Server port to listen for incoming TCP/IP data requests
GetFirmwareVersion
Collects the firmware version from the ESP8266 module and returns it as a string.
- STRING Return
CheckForPageRequests
ClientSendRequest
Sends out a request for data
- STRING Request
e.g. "GET / HTTP/1.0\r\n\r\n"
ReadSSIDFromScan
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first.
- BYTE Index
SSID Index
- STRING Return
CreateAccessPoint
Sets up the wireless LAN module into AP mode to host a wireless network. Other WIFI enabled devices can then connect to the module. Returns 1 for success.
- STRING SSID
- STRING Password
- BYTE Channel
- BYTE Encryption
SetOutValue
- BYTE index
Range 0-4
- STRING value
EndServerConnection
Send_Embedded_HTML_Page4
ReadSignalStrengthFromScan
Collects the signal strength from the last SSID Scan. The ScanForSSID macro must be called first. Value returned is in negative dB, smaller value = better signal
- BYTE Index
SSID Index
- INT Return
Send_Embedded_HTML_Page3
Send_Embedded_HTML_Page2
Send_Embedded_HTML_Page1
ReadEncryptionModeFromScan
Collects one of the encryption modes from the last SSID Scan. The ScanForSSID macro must be called first. 0=Open, 1=WEP, 2=WPA_PSK, 3=WPA2_PSK, 4=WPA_WPA2_PSK
- BYTE Index
SSID Index
GetByteWithTimeout
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available.
GetInValue
- BYTE index
Index of the request paramter, starting at zero Range 0-2
- STRING Return
ConnectToSSID
Attempts to connect to the given SSID and Key values. Returns 1 if the SSID has been connected.
- STRING SSID
- STRING Key
- BYTE Timeout
Number of seconds to wait for the connection, default 2
ClientSendArray
- BYTE Data
- UINT NumBytes
GetRxArray
- BYTE Data
- UINT MaxBytes
ScanForSSID
Checks for wireless networks in the local area which are broadcasting their SSID. Must not be connected to a network to allow this to function. Returns the number of wireless networks found, max 8.
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module
CheckTCPServerIP
Collects the local IP address of the active TCP server.
- STRING Return
