Component: LED MultiColour Tri (5mm, PCB) (LED)
| Author | Matrix Ltd |
| Version | 1.1 |
| Category | LED |
LED MultiColour Tri (5mm, PCB) component
An industry standard 5mm diameter tri-colour LED. Any color may be chosen, and the leads trimmed to length.
Please click here to download the component source project: FC_Comp_Source_led_5mm_tricolour.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_led_5mm_tricolour.fcfx
Tricolour LEDs generally have four pins and come in both common anode and common cathode configurations and must be wired to suit. The tricolour LED component should have a property allowing you to configure which LED type your using.
Six pin tricolour LEDs can simply be treated as three individual standards LEDs.
The series resistor acts to protect each individual LED from damage due to excess current. The value of resistor used can be changed based on the brightness of the LED and power consumption. Usually the three colour LEDs have different characteristics from each other so a different protection resistor should be provided for each LED to balance the LEDs output.
| LEDOff | |
| Switches off the LED | |
| LEDThreeOn | |
| Switches on LED three, other LEDs switched off. | |
| LEDOneOn | |
| Switches on LED one, other LEDs switched off. | |
| LEDTwoOn | |
| Switches on LED two, other LEDs switched off. | |
