Component: COM Port (Runtime Tools)
Jump to navigationJump to search| Author | Matrix Ltd |
| Version | 3.0 |
| Category | Runtime Tools |
- 1 COM Port component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 ReceiveByte
- 5.2 ConfigureConsole
- 5.3 SendString
- 5.4 ReceiveINTArray
- 5.5 ReceiveNumber
- 5.6 SendBinary16Bit
- 5.7 SendINTArray
- 5.8 SendNumber
- 5.9 ReceiveBinary32Bit
- 5.10 ClosePort
- 5.11 ReceiveBinaryFloat
- 5.12 SendByte
- 5.13 SetDTRState
- 5.14 ScanForDeviceID
- 5.15 GetConsoleHandle
- 5.16 SendByteArray
- 5.17 ReceiveBinary16Bit
- 5.18 ReceiveFloat
- 5.19 SendFloat
- 5.20 SendHexNumber
- 5.21 SetFlowControl
- 5.22 OpenPort
- 5.23 ReceiveHexNumber
- 5.24 SetProp
- 5.25 SendBinary32Bit
- 5.26 SendBinaryFloat
- 5.27 GetProp
- 5.28 ReceiveByteArray
- 5.29 ReceiveString
- 6 Property reference
COM Port component
Serial based simulation component for use with systems such as RS232, Bluetooth and USB Serial.
Please click here to download the component source project: FC_Comp_Source_COM_Port.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_COM_Port.fcfx
Auto Detect Port Number
This example auto detects and opens a COM Port based on preassigned USB Identifiers VID/PID.
For a known device the VID and PID can be found via Windows device manager.
ReceiveByte
| ReceiveByte | |
| Attempts to receive a byte using the COM port No valid return data is provided by the timeout value property. | |
| Timeout | |
| Time to wait for incoming data in milliseconds | |
ConfigureConsole
| ConfigureConsole | |
| Status | |
SendString
| SendString | |
| Sends an string of characters to the COM port. | |
| Data | |
| Data byte array to send | |
ReceiveINTArray
ReceiveNumber
SendBinary16Bit
| SendBinary16Bit | |
| Sends out a 16-bit binary value split across two bytes. | |
| Value | |
| MSBfirst | |
| 0=Least significant byte first, 1=Most significant byte first | |
SendINTArray
SendNumber
| SendNumber | |
| Sends out a number as an ASCII String from the UART interface. | |
| Number | |
ReceiveBinary32Bit
ClosePort
| ClosePort | |
| Closes the currently open COM port, ending communications and allowing it to be accessed via another application. | |
ReceiveBinaryFloat
SendByte
| SendByte | |
| Sends a single byte to be sent out via the COM port. | |
| Data | |
SetDTRState
| SetDTRState | |
| Allows the DTR signal to be enabled or disabled. | |
| State | |
| A value of 0 disables the DTR, 1 or above willl enable the DTR. | |
ScanForDeviceID
| ScanForDeviceID | |
| Checks to see if a device VID/PID string is present and returns the COM port number. Returns 0 if device not found. | |
| HWID | |
| Example: "VID_12BF&PID_0101" | |
GetConsoleHandle
| GetConsoleHandle | |
| Gets the handle to the console allowing data displaying on the panel etc. | |
SendByteArray
| SendByteArray | |
| Sends an array of bytes to the COM port. | |
| Data | |
| Length | |
| Number of bytes to send | |
ReceiveBinary16Bit
ReceiveFloat
SendFloat
| SendFloat | |
| Sends out a floating point number as an ASCII String from the UART interface. | |
| Number | |
SendHexNumber
SetFlowControl
| SetFlowControl | |
| Allows the Flowcontrol signals to be enabled or disabled. | |
| State | |
| A value of 0 disables flow control, 1 or above willl enable flow control. | |
OpenPort
| OpenPort | |
| Opens the currently selected COM port, allowing data to be sent and received. | |
ReceiveHexNumber
SetProp
| SetProp | |
| Allows the COM port property to be set from a parent component. | |
| PropName | |
| PropVal | |
SendBinary32Bit
| SendBinary32Bit | |
| Sends out a 32-bit binary value split across four bytes. | |
| Value | |
| MSBfirst | |
SendBinaryFloat
| SendBinaryFloat | |
| Sends out a 32-bit binary floating point value split across four bytes. | |
| Value | |
| MSBfirst | |
GetProp
| GetProp | |
| Allows the property filter for the COM port list to be copied to a parent component. | |
| PropName | |
ReceiveByteArray
ReceiveString
