Component: Car Seat (Scenarios)
Revision as of 11:48, 3 February 2023 by Wiki bot (talk | contribs)
Category Scenarios
Car Seat component
An electric car seat chassis with a series of motors and sensors. Students should work through exercises to learn the principles of electric car seats including how to save and load memory positions.
Please click here to download the component source project: FC_Comp_Source_CarSeatSource_v004.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_CarSeatSource_v004.fcfx
Car Seat Scenario
Save
Save
Saves the current position of the seat into the allocated save slot.
- BYTE SavePos
0 = pos A, 1 = pos B
Load
Load
Moves the seat back into the last saved position stored in the allocated save slot.
- BYTE Location
0 = A, 1 = B
Encoder3
Encoder3
Returns value is equal to Rear Z Axis current value.
- INT Return
Encoder2
Encoder2
Returns value is equal to Front Z Axis current value.
- INT Return
Encoder1
Encoder1
Returns value is equal to X Axis current value (forward/ backwards movement).
- INT Return
CurrentSenseMotor3
CurrentSenseMotor3
This macro is used to sense the current draw from DC motor 3. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
Motor3
Motor3
Controls the Movement of the seat going up and down by the back
- BYTE Direction
0 = Stop, 1 = Up, 2 = Down
CurrentSenseMotor2
CurrentSenseMotor2
This macro is used to sense the current draw from DC motor 2. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
Motor2
Motor2
Controls the Movement of the seat going up and down by the front
- BYTE Direction
CurrentSenseMotor1
CurrentSenseMotor1
This macro is used to sense the current draw from DC motor 1. When it is not being used, it will draw no current. In normal operating conditions it will draw 3A, and under stall conditions (when the motor hits the end stops) it will draw 20A.
Motor1
Motor1
Moves the Car Seat Forwards and Backwards
- BYTE Direction
0 = Stop, 1 = Forward, 2 = Backward
Show seat base?
Controls if the base of the car seat is shown on the simulation panel.
