| Author
MatrixTSL
| Version
1.0
| Category
Sensors
Digital Multimeter component
A component allowing access to the digital multimeter IC HY3131.
Please click here to download the component source project: FC_Comp_Source_DMM_HY3131.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_DMM_HY3131.fcfx
ReadRegister
ReadRegister
| A simple example showing a generic way to read a register using I2C.
- BYTE
Address
- BYTE
WriteRegister
WriteRegister
| A simple example showing a generic way to write a register using I2C.
- BYTE
Address
- BYTE
Data
SPI Properties
| SPI Channel selector
MOSI
MISO
CLK
Use Auto CS
| Allow the SPI component to manage the CS pin for us in Master mode. On initialise the CS pin is automatically set high to disable the remote SPI device. Set to No if you want to create a component with multiple CS pins or if you want to manage the CS pin yourself.
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Options
Mode
| Configures the mode of the SPI component. Currently only Master mode is supported.
Prescale
| Prescale option selector
Clock Phase
| Clock Phase (data change edge) selection
Clock Polarity
| Clock Polarity setting, inactive (idle) state
Sample Point
| Data bit read sample point
Simulate Comms
Scale
Select Scale
