Component: DMX-512 Master (Comms: System)
Author | MatrixTSL |
Version | 2.0 |
Category | Comms: System |
DMX-512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
Please click here to download the component source project: FC_Comp_Source_DMX-512_Master_SCADA.fcsx
Please click here to view the component source code (Beta): FC_Comp_Source_DMX-512_Master_SCADA.fcsx
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet.
For DMX 512 slave example see: DMX Slave
SetDataChannel
SetDataChannel |
Sets the data byte in a data channel | |
Channel |
DataValue |
Return |
SendDataChain
SendDataChain |
Transmits the BREAK, MAB and StartCode followed by the contents of the data channels. | |
StartCode |
Return |
Initialise |
Configures the UART serial interface. | |
Return |
