Component: API (ESP32) (API Slave Devices)
Revision as of 11:49, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category API Slave Devices
API (ESP32) component
Connects to an ESP32 device running the API Firmware allowing the board to become a slave to the Flowcode Embedded simulation or Flowcode App Developer. Supports: Digital IO / ADC / I2C / SPI / PWM / UART See Flowcode Help Wiki for firmware.
Please click here to download the component source project: FC_Comp_Source_ESP32_API_Comp.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_ESP32_API_Comp.fcfx
The App Developer (ESP32) component allows an ESP32 board to be controlled from within the Flowcode simulation runtime.
To allow Flowcode to communicate and control the ESP32 hardware the board must first be pre-programmed with dedicated firmware.
The firmware source project can be downloaded from here.
You will need to set your WIFI SSID and Password near the top of Main to allow the ESP module to connect to your network.
ZIP Icon.png ESP32 App Developer Firmware
The IP Address to the ESP32 hardware is selected via the SCADA_ESP32 component IP Address property.
When building the component into a App Developer project remember to expose the IP Address property to allow the end user to select the address for the hardware.
  • fixed statistics showing IO / ADC inputs / PWM
  • scrolling log showing all commands and returns
Pin Mapping
Please note pins 34, 35, 36, 39 are only capable of digital inputs and cannot be used as digital outputs.
App Developer Slave Digital Pin 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 21 22 23 25 26 27 32 33 34 35 36 39
Device Port Pin A0 A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 A16 A17 A18 A19 A21 A22 A23 A25 A26 A27 B0 B1 B2 B3 B4 B7
GPIO Number 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 21 22 23 25 26 27 32 33 34 35 36 39
Please note not all analogue input pins are available as peripheral ADC2 is not accesible when WIFI/Bluetooth is active. Only the pins shown are available.
App Developer Slave Analogue Pin 0 3 4 5 6 7
Device Port Pin B4 B7 B0 B1 B2 B3
GPIO Number 36 39 32 33 34 35
Please note that PWM channels are tied in pairs and so channel 0 and 1 use the same internal timer peripheral. They will always run at the same frequency and when enabling channel 1 channel 0 duty will be reset to 0% and visa versa.
App Developer Slave Peripheral Pin I2C 0 SDA I2C 0 SCL I2C 1 SDA I2C 1 SCL SPI 0 MOSI SPI 0 MISO SPI 0 SCK SPI 1 MOSI SPI 1 MISO SPI 1 SCK UART 0 RX UART 0 TX UART 1 RX UART 1 TX PWM 0 PWM 1 PWM 2 PWM 3 PWM 4 PWM 5 PWM 6 PWM 7 PWM 8 PWM 9 PWM 10 PWM 11 OneWire
Device Port Pin A13 A12 A15 A14 A9 A10 A11 A6 A7 A8 A26 A25 B0 B1 A0 A2 A4 A5 A12 A13 A14 A15 A16 A17 A18 A19 A21
GPIO Number 13 12 15 14 9 10 11 6 7 8 26 25 32 33 0 2 4 5 12 13 14 15 16 17 18 19 21
PortA = GPIO pins 0 - 31 : A0 = GPIO 0
PortB = GPIO pins 32 - 39 : B0 = GPIO 32
I2CInitialise
Fc9-comp-macro.png I2CInitialise
Initialise the I2C module ready for communications
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
ADCSampleArray8
Fc9-comp-macro.png ADCSampleArray8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples and returns each sample in a single packet
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0, 3-7
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u8-icon.png - BYTE Samples
8-bit samples returned from the function
SPITransferTrans
Fc9-comp-macro.png SPITransferTrans
Fc9-u16-icon.png - UINT Count
Outgoing data
Fc9-u8-icon.png - BYTE DataIn
Incoming data
OneWireBusReset
Fc9-comp-macro.png OneWireBusReset
Issue a 'ping' on the bus. If there is at least one sensor on the bus then it will generate a presence pulse. Returns 0 if a presense pulse was detected Returns 1 no device was detected
IOGetInputPin
Fc9-comp-macro.png IOGetInputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-29
UARTBaud
Fc9-comp-macro.png UARTBaud
Fc9-u8-icon.png - BYTE Rate
OneWireInitialise
Fc9-comp-macro.png OneWireInitialise
Initialise the OneWire module ready for communications
OneWireMatchROM
Fc9-comp-macro.png OneWireMatchROM
Performs a reset followed by the MatchROM code and then the 8-bit ROM code.
Fc9-u8-icon.png - BYTE FamilyCode
Fc9-u8-icon.png - BYTE SerialNumber
ADCSample8
Fc9-comp-macro.png ADCSample8
Range: 0, 3-7
I2CTransReceive
Fc9-comp-macro.png I2CTransReceive
Data variable to receive into
Number of bytes to receive
UARTInitialise
Fc9-comp-macro.png UARTInitialise
UARTCheckRX
Fc9-comp-macro.png UARTCheckRX
ADCSetPrechargeTime
Fc9-comp-macro.png ADCSetPrechargeTime
Specifies the precharge time for the ADC input readings in microseconds. The longer the time the more immune to noise the reading will be.
Fc9-u8-icon.png - BYTE ChargeTime
Default 10
OneWireTransmitByte
Fc9-comp-macro.png OneWireTransmitByte
Transmit a byte to the one wire bus a bit at a time
I2CRestart
Fc9-comp-macro.png I2CRestart
PWMDisable
Fc9-comp-macro.png PWMDisable
Disable a PWM output
Range: 0-11
I2CStart
Fc9-comp-macro.png I2CStart
SPITransfer
I2CReceive
Fc9-comp-macro.png I2CReceive
Fc9-bool-icon.png - BOOL Last
OneWireGetIDByte
Fc9-comp-macro.png OneWireGetIDByte
Returns a single byte of the 64-Bit lasered ROM code, 255 on error
Fc9-u8-icon.png - BYTE Device
Device ID - Range: 0 - NumDevices - 1
Fc9-u8-icon.png - BYTE ByteIndex
Index of the data byte. 0=FamilyCode, 1-6=Serial, 7=CRC
PWMSetFrequency
Fc9-comp-macro.png PWMSetFrequency
Sets PWM frequency in Hz
Range: 0 - 11
Fc9-s32-icon.png - LONG Frequency
Frequency (Hz)
I2CStop
Fc9-comp-macro.png I2CStop
ADCSetReferenceVoltage
Fc9-comp-macro.png ADCSetReferenceVoltage
Specified the reference setting for ADC reads.
Fc9-u8-icon.png - BYTE RefType
0=AREF, 1=VCC, 3=Internal 1.1V
OneWireSkipROM
Fc9-comp-macro.png OneWireSkipROM
Performs a bus reset and the sends the SkipROM command byte
SPIPrescaler
Fc9-comp-macro.png SPIPrescaler
Range: 0-2
PWMSetDuty
Fc9-comp-macro.png PWMSetDuty
Range: 0-11
Fc9-u8-icon.png - BYTE Duty
ADCSample10
Fc9-comp-macro.png ADCSample10
Reads the voltage present on an Analog pin as an 12-bit value range 0-4095
Range: 0, 3-7
I2CTransSend
Fc9-comp-macro.png I2CTransSend
Data to send
I2CTransInit
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
IOSetOutputPin
Fc9-comp-macro.png IOSetOutputPin
Range: 0-29
Fc9-bool-icon.png - BOOL State
Range: 0-1
UARTReceive
ADCSampleAverage10
Fc9-comp-macro.png ADCSampleAverage10
Range: 0, 3-7
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
OneWireScanBus
Fc9-comp-macro.png OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
SPIInitialise
Fc9-comp-macro.png SPIInitialise
OneWireReceiveByte
Fc9-comp-macro.png OneWireReceiveByte
I2CSend
Fc9-comp-macro.png I2CSend
UARTSend
Fc9-comp-macro.png UARTSend
OneWireGetDeviceCount
Fc9-comp-macro.png OneWireGetDeviceCount
PWMEnable
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-11
ADCSampleArray10
Fc9-comp-macro.png ADCSampleArray10
Range: 0, 3-7
Range: 1- 32
Fc9-u16-icon.png - UINT Samples
ADCSampleAverage8
Fc9-comp-macro.png ADCSampleAverage8
Range: 0, 3-7
Range: 1- 100
Fc9-comp-macro.png Initialise
Fc9-conn-icon.png Connection
Fc9-type-10-icon.png ESP IP Address
IP Address of the Raspbery Pi we want to control
Fc9-type-21-icon.png ESP Port
Port number we want to communicate on. Default 1234
Fc9-type-16-icon.png Network Interface
Some computers may have several network interfaces such as ethernet ports and wifi access. Select the correct network interface for the network you wish to connect to. Use the IP address to confirm you are connected to the right network.
Fc9-type-10-icon.png IP Address
IP Address of the selected network interface.
Fc9-conn-icon.png API Peripherals
Fc9-type-21-icon.png Digital IO
Fc9-type-21-icon.png Analog Input
Fc9-type-21-icon.png Analog Output
Fc9-type-21-icon.png PWM Output
Fc9-type-21-icon.png I2C Bus
Fc9-type-21-icon.png SPI Bus
Fc9-type-21-icon.png UART
Fc9-type-21-icon.png OneWire
Fc9-type-21-icon.png SERVO
Fc9-conn-icon.png Console
Fc9-type-7-icon.png Console Log
Create an automatic console log of the commands sent to the ESP
Fc9-type-16-icon.png Log Mode
Controls how the console data is formatted. Fixed statistics gives an easy to read overview of the IO, Analog and PWM functionality Command Log gives a more in depth analysis of the outgoing commands and incoming returns ASCII mode allows serial data to be shown in raw text form, other commands are shown as in the Command Log mode
