Component: Formula AllCode Dummy (RB4420) (Mechatronics)
| Version | 1.2 |
| Category | Mechatronics |
- 1 Formula AllCode Dummy component
- 2 Component Source Code
- 3 Detailed description
- 4 Examples
- 5 Macro reference
- 5.1 PlayNote
- 5.2 LEDOn
- 5.3 BluetoothTransmit
- 5.4 LCDPrintString
- 5.5 Stop
- 5.6 ReadBattery
- 5.7 LEDOff
- 5.8 LCDPrintNumber
- 5.9 LEDWrite
- 5.10 BluetoothCheckConnection
- 5.11 ReadMic
- 5.12 AudioQueueLength
- 5.13 AudioAddToBuffer
- 5.14 ReadSwitch
- 5.15 CheckLine
- 5.16 AudioStreamControl
- 5.17 SpinLeft
- 5.18 LogoTurnLeft
- 5.19 Forward
- 5.20 LCDWriteByte
- 5.21 BluetoothReceive
- 5.22 LCDDrawLine
- 5.23 BluetoothQueueLength
- 5.24 BluetoothTransmitString
- 5.25 LCDBacklight
- 5.26 AudioReadFromBuffer
- 5.27 ReadLineSensor
- 5.28 LogoTurnRight
- 5.29 SpinRight
- 5.30 CheckIR
- 5.31 LCDPlotPixel
- 5.32 LCDSetBackgroundColour
- 5.33 ReadIRSensor
- 5.34 SetMotors
- 5.35 LogoBackwards
- 5.36 EncoderReset
- 5.37 Reverse
- 5.38 WaitForSwitch
- 5.39 ReadLDR
- 5.40 LCDDrawRectangle
- 5.41 EncoderReadCount
- 5.42 CheckUSB
- 5.43 LCDSetForegroundColour
- 5.44 Initialise
- 5.45 LogoSetSpeed
- 5.46 LogoForwards
- 5.47 LCDClear
- 6 Property reference
A component to allow all the features of the Formula AllCode robot to be investigated. Fully simulated component which can interact with simulated objects on the panel as well as control the real hardware.
Please click here to download the component source project: FC_Comp_Source_FA_Source_P4_Dummy_Template.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_FA_Source_P4_Dummy_Template.fcfx
Line Following
Line following example using the Formula AllCode, works with objects on the simulation panel and on the real hardware.
Simulation with the API component
An example showing how to use the API component to drive the robot in simulation.
PlayNote
LEDOn
| LEDOn | |
| Switches on a single LED on the front of the Formula Allcode. | |
| LED | |
| Which LED to switch on, range 0-7 | |
BluetoothTransmit
| BluetoothTransmit | |
| Sends a byte via the Bluetooth data connection. | |
| Data | |
LCDPrintString
Stop
| Stop | |
| Stops both motors. | |
ReadBattery
LEDOff
| LEDOff | |
| Switches off a single LED on the front of the Formula Allcode. | |
| LED | |
LCDPrintNumber
LEDWrite
| LEDWrite | |
| Allows control of all 8-LEDs on the front of the Formula Allcode. | |
| LED_Byte | |
| 8-bit binary value to write to the 8 LEDs | |
| BluetoothCheckConnection | |
| Checks the status of the Bluetooth connection. Returns 0 for not paired and 1 for paired. | |
ReadMic
| ReadMic | |
| Reads the current audio signal level from the on-board microphone. Return value range: 0 to 4095 | |
AudioQueueLength
| AudioQueueLength | |
| Retreives the current length of valid data within the audio queue | |
AudioAddToBuffer
| AudioAddToBuffer | |
| Writes a value to the 16-bit audio output buffer. | |
| Data | |
ReadSwitch
| ReadSwitch | |
| Reads the value of one of the switches from the front of the Formula Allcode. | |
| Switch | |
| Which switch do we want to read 0=Left, 1=Right | |
CheckLine
AudioStreamControl
SpinLeft
| SpinLeft | |
| Spins the formula flowcode on the spot in an anticlockwise direction as seen from above. | |
| Power | |
| Amount of power to use to drive motor. Range 0-100 | |
LogoTurnLeft
Forward
| Forward | |
| Drives both motors of the formula flowcode forwards with the power specified. | |
| Power | |
LCDWriteByte
| LCDWriteByte | |
| Data | |
| X | |
| Y | |
BluetoothReceive
| BluetoothReceive | |
| Attempt to read a byte from the Bluetooth receive queue. | |
LCDDrawLine
| LCDDrawLine | |
| Draws a line on the LCD. | |
| X1 | |
| Range 0-127 | |
| Y1 | |
| Range 0-31 | |
| X2 | |
| Range 0-127 | |
| Y2 | |
| Range 0-31 | |
| BluetoothQueueLength | |
| Reads the length of received Bluetooth data in bytes. | |
| BluetoothTransmitString | |
| Sends a string via the Bluetooth data connection. | |
| Data | |
LCDBacklight
| LCDBacklight | |
| Controls the brighness of the LCD backlight | |
| Brightness | |
| Range: 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
AudioReadFromBuffer
| AudioReadFromBuffer | |
| Allows the audio buffer to be used for other streaming data such as recording the mic. | |
ReadLineSensor
LogoTurnRight
SpinRight
| SpinRight | |
| Spins the formula flowcode on the spot in a clockwise direction as seen from above. | |
| Power | |
CheckIR
LCDPlotPixel
| LCDPlotPixel | |
| Allows a single pixel on the LCD to be set or cleared. | |
| X | |
| Sets the X coordinate - Range 0-127 | |
| Y | |
| Sets the Y coordinate - Range 0-31 | |
| LCDSetBackgroundColour | |
| Sets the pixel colour to drive the LCD. Default colour is 1 where a set pixel is black and the background is white. | |
| Colour | |
| Range 0-1 : 0=White, 1=Black | |
ReadIRSensor
SetMotors
| SetMotors | |
| Sets the speed and direction of the Formula Allcode motors. | |
| Left | |
| Valid Range = -100 to 100 | |
| Right | |
LogoBackwards
EncoderReset
| EncoderReset | |
| Resets the encoder counters to 0 | |
Reverse
| Reverse | |
| Drives both motors of the formula flowcode backwards with the power specified. | |
| Power | |
WaitForSwitch
| WaitForSwitch | |
| Waits for the specified switch to be pressed. | |
| Switch | |
| Which switch do we want to wait for 0=Left, 1=Right, 2=Either, 3=Both | |
ReadLDR
LCDDrawRectangle
EncoderReadCount
| EncoderReadCount | |
| Reads one of the motor encoder counters. Each encoder count is equal to 0.314159 mm. | |
| Channel | |
| 0 = LeftCount, 1=RightCount | |
CheckUSB
| CheckUSB | |
| Checks to see if a USB cable is connected to the robot. Returns 0 for no connection and 1 for an active connection. | |
| LCDSetForegroundColour | |
| Colour | |
| Starts up the Formula Allcode PWM for motor control and performs the wait for button press if enabled. | |
LogoSetSpeed
| LogoSetSpeed | |
| Sets the cruise speed for LOGO type macros. Default speed 20%. | |
| Speed | |
| Range 1-100, Default 60 | |
LogoForwards
LCDClear
| LCDClear | |
| Clears the contents of the graphical LCD. | |
