Component: GLCD (SSD1289) (Graphical Color)
Revision as of 11:50, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.6
Category Graphical Color
GLCD (SSD1289) component
Graphical display component based on the SSD1289 16-bit colour graphical controller IC.
Please click here to download the component source project: FC_Comp_Source_GLCD_SSD1289.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_SSD1289.fcfx
ReadFontWidth
ReadFontWidth
- BYTE Font
- BYTE Character
BacklightOn
BacklightOn
Sets the backlight enable pin allowing the display backlight to switch on. Switching the backlight on and off at high speed allow the light to be dimmed.
SetFontScaler
SetFontScaler
- BYTE ScaleX
- BYTE ScaleY
- INT Number
- UINT X
- UINT Y
- BYTE Font
- BYTE Transparent
DrawLine
DrawLine
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
DrawEllipse
DrawEllipse
- UINT X
- UINT Y
- UINT XRadius
- UINT YRadius
- BYTE Transparent
- BYTE Solid
Plot
Plot
- UINT X1
- UINT Y1
FastPlot
FastPlot
SetDisplayOrientation
- BYTE Orientation
BacklightOff
BacklightOff
Clears the backlight enable pin allowing the display backlight to switch off. Switching the backlight on and off at high speed allow the light to be dimmed.
BPlot
BPlot
- UINT X1
- UINT Y1
Window
Window
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
ReadFontStat
ReadFontStat
- BYTE Font
- BYTE Index
0=SpaceWidth, 1=PixelHeight
Print
Print
- STRING Str
- UINT X1
- UINT Y1
- BYTE Font
- BYTE Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawCircle
DrawCircle
- UINT X
- UINT Y
- UINT Radius
- BYTE Transparent
- BYTE Solid
SetForegroundColour
SetForegroundColour
- BYTE Red
- BYTE Green
- BYTE Blue
DrawRectangle
DrawRectangle
- UINT X1
- UINT Y1
- UINT X2
- UINT Y2
- BYTE Transparent
- BYTE Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Chip Select (CS)
Chip select pin connection
Reg Select (CD)
Read (RD)
Reset pin connection
Write (RW)
Data Port Low
Data Port High
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Component Label
User Label Text
Text to display
Component Label Scale
Physical Orientation
