| Author
Matrix Ltd
| Version
1.5
| Category
Graphical Monochrome
GLCD (ST7565R) Parallel component
Graphical display component designed to work with the ST7565 type monochrome displays. Transfers data using an 8-bit digital data bus.
Please click here to download the component source project: FC_Comp_Source_GLCD_ST7565R.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_GLCD_ST7565R.fcfx
ReadFontWidth
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
- INT
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
ReadFontStat
- BYTE
Font
- BYTE
Index
| 0=SpaceWidth, 1=PixelHeight
- BYTE
Print
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ClearDisplay
ClearDisplay
SetBackgroundColour
SetBackgroundColour
| Specifies the colour of the foreground
- BYTE
PixelColour
| 0=White, 1=Black
DrawCircle
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
SetForegroundColour
| Specifies the colour of the foreground.
- BYTE
PixelColour
| 0=White, 1=Black
DrawRectangle
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Dimensions
Pixel Width
Pixel Height
Colour
Monochrome
Foreground Color
Background Color
Bit Depth
Color Bit Depth
| Number of bits of colour depth available on the display
Red Bit Depth
| Number of bits of Red colour depth on the display
Green Bit Depth
| Number of bits of Green colour depth on the display
Blue Bit Depth
| Number of bits of Blue colour depth on the display
Data Pins
| Decides if the 8-bit data bus is controlled using a full port or individual pins. A full port will run faster whereas individual pins allow for more flexibility.
DATAPORT
CS1
| Chip select pin
RES
| Reset pin
A0
| Address pin to tell the display if we are sending commands or data
RD_E
| Enable pin used to clock data into the display
WR_RW
| Read Write pin to set the display data mode
MODE
Fonts
Font Count
Font 0
Font
Character Spacing
Space Width
Simulation Mode
Physical Orientation
