Component: Injector (File) (Test Injectors)
| Author | Matrix Ltd |
| Category | Test Injectors |
Injector (File) component
Comms data injector to allow data to be streamed to and from a file during simulation. The component will read data from the incoming file and write data to the outgoing file.
Please click here to download the component source project: FC_Comp_Source_InjectorFile.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_InjectorFile.fcfx
Example to log the bytes sent via the UART RS232 component to a file as comma separated decimal numbers.
LogToFile
Contents of the file in the Flowcode project directory after running the simulation.
SPITransferTrans
UARTBaud
| UARTBaud | |
| Channel | |
| Rate | |
UARTCheckRX
| UARTCheckRX | |
| Channel | |
UARTInitialise
| UARTInitialise | |
| Channel | |
SPITransfer
| SPITransfer | |
| Transfer a byte using the SPI bus | |
| Channel | |
| DataOut | |
SPIPrescaler
| SPIPrescaler | |
| Modify the speed of the SPI bus | |
| Channel | |
| Prescaler | |
| Range: 0-2 | |
UARTReceive
| UARTReceive | |
| Channel | |
SPIInitialise
| SPIInitialise | |
| Channel | |
UARTSend
| UARTSend | |
| Channel | |
| Data | |
