| Author
Matrix TSL
| Version
1.4
| Category
Segment
Starburst Display 2D component
Starburst 14 or 16 segment display modelled after a standard 14mm high unit. LED colour can be changed in properties.
Please click here to download the component source project: FC_Comp_Source_LED_Starburst_Single_2dgi.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_LED_Starburst_Single_2dgi.fcfx
ClearSegments
ClearSegments
| This funtion clears all the individual segments including the decimal point segment. In simulation this sets the colours to the default BGColor component variable.
ShowSegments
ShowSegments
| Creates the supplied digit on the 7 segment display. Macro takes the digit to display and a boolean representing whether to display the decimal point segment or not.
- BYTE
Segments0
| Segment bits 0=Off 1=On : F/E/D2/D/C/B/A2/A
- BYTE
Segments1
| Segment bits 0=Off 1=On : M/L/K/J/I/H/G2/G1
- BYTE
DecimalPoint
| Segment bits 0=Off 1=On : DecimalPoint
ShowCharacter
ShowCharacter
| Allows certain pre-programmed characters to be displayed. 0-9, A-Z, $, [, ], +, -, \, /, *, _, {, }, .
- BYTE
Character
| 0-9 or A-Z
- BYTE
DecimalPoint
| 0=Off, 1=On
Display Segments
| Controls the starburst display type and number of segments available.
Display Type
| Set this property to match your hardware device. Common Anode: Common Pin High, Segment Pin Low = LED On Common Cathode: Common Pin Low, Segment Pin High = LED On
Common Mode
| Controls if the display will be multiplexed or always on. Multplexed uses the common pin to switch a individual display on or off allowing for multiple displays. Always on removes the common pin assuming you are only using a single starburst display.
Show Seg Labels
| Show the identifier lables of the segments overlayed over the component.
Pin A
| Pin connected to the 'A' segment of the display.
Pin B
| Pin connected to the 'B' segment of the display.
Pin C
| Pin connected to the 'C' segment of the display.
Pin D
| Pin connected to the 'D' segment of the display.
Pin E
| Pin connected to the 'E' segment of the display.
Pin F
| Pin connected to the 'F' segment of the display.
Pin G1
| Pin connected to the 'G1' segment of the display.
Pin G2
| Pin connected to the 'G2' segment of the display.
Pin H
| Pin connected to the 'H' segment of the display.
Pin I
| Pin connected to the 'I' segment of the display.
Pin J
| Pin connected to the 'J' segment of the display.
Pin K
| Pin connected to the 'K' segment of the display.
Pin L
| Pin connected to the 'L' segment of the display.
Pin M
| Pin connected to the 'M' segment of the display.
Pin DP
| Pin connected to the decimal point segment of the display.
Common
| Pin connection to the 'common' pin of the display - to allow enable/disable of the whole display.
Colors
LED Color
| Color when an LED is turned on. When turned off, will use a much darker shade of the same hue.
Bezel Color
| Color of the plastic package housing the LEDs
Label Color
| Color of the optional segment name labels.
