| Author
Matrix TSL
| Version
1.0
| Category
General Input
IO Expander (MCP23S17) component
Provides 16 digital input/output pins arranged into two 8-bit ports using a SPI bus connection. Multiple expanders can be connected to the same SPI peripheral by means of individual chip select pins.
Please click here to download the component source project: FC_Comp_Source_MCP23S17.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MCP23S17.fcfx
ReadPort
ReadPort
| Reads a value to one of the ports with a mask. Configures the masked bits to be inputs before reading the input value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
| Allows port bits to be modified without effecting other bits, 255 = write full port.
- BYTE
ConfigureInversion
ConfigureInversion
| Configures the pin inversion for the two ports. Disabled on all pins by default.
- BYTE
PortA
| Port A inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
| Port B inversion sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadPortPin
ReadPortPin
| Reads a single port pin from one of the ports. Configures the pins to be an input before reading the input value. Returns 0 or 1 corresponding to the value on the port pin.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
| Port pin to read. Range: 0-7
- BYTE
WritePortPin
WritePortPin
| Writes a single port pin on one of the ports. Configures the pins to be an output before writing the input value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Pin
- BYTE
Value
| Value to output on the selected pin. Range: 0-1
WritePort
WritePort
| Writes a value to one of the ports with a mask. Configures the masked bits to be outputs before writing the output value.
- BYTE
Port
| 0=PortA, 1=PortB
- BYTE
Mask
- BYTE
Value
| Value to write. Range 0-255
ConfigurePullups
ConfigurePullups
| Configures the pullups for the two ports. Disabled on all pins by default.
- BYTE
PortA
| Port A pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
- BYTE
PortB
| Port B pull ups sent as an 8-bit value, 0 = Disabled, 1 = Enabled
ReadRegister
ReadRegister
| Reads an 8-bit value from a register on the I/O expander device.
- BYTE
Address
| Register address to write to. Range: 0-15
- BYTE
WriteRegister
WriteRegister
| Writes an 8-bit value to a register on the I/O expander device.
- BYTE
Address
- BYTE
Value
| Value to write. Range: 0-255
SPI Communications
External Address
| Selects the value of the three address pins for the MCP23S17.
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Use Reset
API
