Component: MIAC (dsPIC) (MIAC (dsPIC)) (Misc)
Revision as of 11:51, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Misc
MIAC (dsPIC) component
MIAC - Matrix Industrial Automotive Controller (dsPIC)
Please click here to download the component source project: FC_Comp_Source_MIAC_(dsPIC).fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_MIAC_(dsPIC).fcfx
RelayOFF
RelayOFF
Turns off the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
The relay to turn off. From 1 to 4.
InputANALOG_10Bit
InputANALOG_10Bit
- BYTE InputID
The input to read. From 1 to 8.
- INT Return
PrintString
PrintString
Prints the given character string to the display at the current cursor position and moves the cursor position.
- STRING Str
The string to send to the display.
GetKeypad
GetKeypad
Returns the key code of the key that is pressed, otherwise if nothing is pressed then returns 255
DisplayStart
DisplayStart
Initialise the display ready for use
Prints the given number to the display starting at the current cursor position and moves the cursor position.
- INT n
PrintASCII
PrintASCII
Prints the given character to the display at the current cursor position and increments the cursor position.
- BYTE Char
ASCII code of the character to print.
DrawLine
DrawLine
Draws or clears a line from start at sx:sy to end at ex:ey
- BYTE sx
Start column position
- BYTE sy
Start row position
- BYTE ex
End column position
- BYTE ey
End row position
- BYTE state
1=active pixel, 0=cleared pixel
PrintFormattedNumber
- ULONG Number
- BOOL Format
0=Signed, 1=Unsigned
DrawRect
DrawRect
Draws a rectangular box from x1,y1 to x2,y2
- BYTE x1
- BYTE y1
- BYTE x2
- BYTE y2
- BYTE state
1=draw pixel, 0=clear pixel
DisplayClear
DisplayClear
Clears the display to white space
RelayON
RelayON
Turns on the requested relay given by parameter RelayID, values 1 to 4
- BYTE RelayID
The relay to turn on from 1 to 4.
OutputOFF
OutputOFF
Outputs a digital low state on the output requested by parameter TransID (Outputs 1 to 4)
- BYTE TransID
1 to 4 (Outputs A to D)
DrawPixel
DrawPixel
Draws, or clears, a pixel at point x,y
- BYTE px
- BYTE py
- BYTE state
state = 0 clears the pixel, else draws the pixel
DisplayCursor
DisplayCursor
Moves the display cursor to the given position. If the cursor is set to the origin at x=0, y=0, then the next character sent to the display will appear in the top left corner.
- BYTE x
Position of the cursor in characters from left to right.
- BYTE y
The line to move the cursor to.
OutputON
OutputON
Outputs a digital high state on the output requested by parameter TransID (Outputs 1 to 4)
- BYTE TransID
InputDIGITAL
InputDIGITAL
Returns the digital state of the input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
The input number from 1 to 8.
DisplayLight
DisplayLight
Turns the display backlight on or off
- BYTE state
DrawGlyph
DrawGlyph
Draws a character glyph on the display at position px, py
- BYTE glyph
The glyph ident number
- BYTE px
pixel column relative to the drawing origin (top left)
- BYTE py
pixel row relative to the drawing origin (top left)
- BYTE mode
0=opaque/cleared background, 1=transparent background
InputANALOG
InputANALOG
Returns the 8 bit value for the analogue input requested by parameter InputID (Inputs 1 to 8)
- BYTE InputID
The input to read from 1 to 8.
