Component: Servo Controller Mod (Mechatronics)
| Author | Matrix Ltd |
| Version | 1.5 |
| Category | Mechatronics |
Servo Controller Mod component
Can control up to eight standard PWM driven servo's. 'Servo Object' properties allow you to connect the controller to on-screen simulations using the "Servo Motor" component and its derivatives.
Please click here to download the component source project: FC_Comp_Source_Servo_Controller_Mod.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Servo_Controller_Mod.fcfx
Importing from v5
The servo component in Flowcode v6 onwards has a new Initialise macro which will need to be added to your program before any other calls to the servo motor component are made.
Controlling a servo with an analogue input
This example reads the value of the analogue potentiometer and uses this to set the position of the servo motor.
Servo Example 1
The Servo controller is linked to the standard servo component but this could be linked to any object on the panel.
Creating a multi-axis actuator using servo motors
This example links two servo motors together using panel primitive objects and groups.
Servo Example 2
The Servo controller can handle up to 8 motors and is used to control both of the standard servo components on the panel.
DisableServo
| DisableServo | |
| Disables a servo channel effectivly disabling the motor. | |
| Channel | |
| The channel to set the position for. First channel is zero. | |
SetPosition
MoveToPosition
SetTrim
IsAutoMoving
| IsAutoMoving | |
| Is the AutoMoveToPosition movement complete. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete. | |
AutoMoveToPosition
EnableServo
SetAutoMoveSpeed
| SetAutoMoveSpeed | |
| Sets the speed of the auto move to position macro. Default speed is 1. | |
| Speed | |
| 1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple | |
| Sets up the servo motor interrupts | |
