Component: Sound Sensor (Grove 101020023) (101020023) (Audio)
Revision as of 11:52, 3 February 2023 by Wiki bot (talk | contribs)
Category Audio
Sound Sensor (Grove 101020023) component
The Sound sensor module is a simple microphone. Based on the power amplifier LM386 and the electret microphone, it can be used to detect the sound strength of the environment.
Please click here to download the component source project: FC_Comp_Source_Sound_Sensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_Sound_Sensor.fcfx
GetString
GetString
Reads the ADC as a direct voltage and returns as as tring
- STRING Return
GetAverageByte
GetAverageByte
Function call to read the ADC as a byte average sample over time
- BYTE NumSamples
- BYTE DelayUs
Number of micro seconds in between taking each sample
GetAverageInt
GetAverageInt
Function call to read the ADC as a full width average sample over time
- BYTE NumSamples
- BYTE DelayUs
GetVoltage
GetVoltage
- FLOAT Return
GetInt
GetInt
Blocking call to read the ADC at full bit depth
GetByte
GetByte
Blocking call to read the ADC as a byte
Tang Color
Colour of the moving part of the slider.
Marker Color
Colour of the marker line across the slider tang.
Settings
VRef voltage
VRef option
Conversion speed
Aquisition cycles
Bit Depth
