| Author
Matrix Ltd
| Version
2.0
| Category
Comms: Networking
TCP/IP DUMMY component
TCP/IP component designed to work with the WIZ3100 range of modules from Wiznet. Also available in the form of the version 1 EB023 E-block which uses the NM7010A module.
Please click here to download the component source project: FC_Comp_Source_TCPIP_EB023-00-1_Dummy.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_EB023-00-1_Dummy.fcfx
InitialiseSim
InitialiseSim
| Resets and initialises the Internet E-Block. It sets up the gateway address, subnet mask, device IP address and device MAC address as defined in the properties of the Flowcode component. This macro must be called before any other TCP_IP component macros
TxSendMyIP
TxSendMyIP
| This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE
| Specifies the communications channel 0-3
TxSendString_Sim
TxSendString_Sim
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE
- STRING
Data
| Data byte to append to Tx buffer.
- BYTE
Length
RxReadHeader_Sim
| A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Idx
- BYTE
RxMatch_6_Bytes_Sim
RxMatch_6_Bytes_Sim
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE
- BYTE
Byte1
| Specifies the value of the first byte
- BYTE
Byte2
| Specifies the value of the second byte
- BYTE
Byte3
| Specifies the value of the third byte
- BYTE
Byte4
| Specifies the value of the fourth byte
- BYTE
Byte5
| Specifies the value of the fifth byte
- BYTE
Byte6
| Specifies the value of the sixth byte
- BYTE
RxMatchMyIP
RxMatchMyIP
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE
- BYTE
TxStart_Sim
TxStart_Sim
| This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE
TCPClose_Sim
TCPClose_Sim
| When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE
RxDataAvailable_Sim
RxDataAvailable_Sim
| This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE
- BYTE
RxMatch_4_Bytes
RxMatch_4_Bytes
| This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
SetMyIP
SetMyIP
| This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE
IP0
| First Byte of IP address
- BYTE
IP1
| Second Byte of IP address
- BYTE
IP2
| Third Byte of IP address
- BYTE
IP3
| Fourth Byte of IP address
TxSendString
TxSendString
- BYTE
- STRING
Data
- BYTE
Length
SetDestination_Sim
SetDestination_Sim
| This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE
- BYTE
Dst_IP0
| Specifies the first byte of an IP address
- BYTE
Dst_IP1
| Specifies the second byte of an IP address
- BYTE
Dst_IP2
| Specifies the third byte of an IP address
- BYTE
Dst_IP3
| Specifies the fourth byte of an IP address
- BYTE
Dst_Port_Hi
| Port High Byte
- BYTE
Dst_Port_Lo
| Port Low Byte
TxSendMyMAC_Sim
TxSendMyMAC_Sim
| This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE
RxSkipBytes_Sim
RxSkipBytes_Sim
| Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE
- BYTE
Count
| Specifies how many bytes to skip
CreateIPSocket_Sim
CreateIPSocket_Sim
| Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE
- BYTE
Protocol
| Specifies which IP protocol to use
- BYTE
Broadcast
| Allows broadcast type packets to be sent and received
- BYTE
RxReadHeader
| Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE
- BYTE
Idx
| Specifies the byte index to return
- BYTE
TxSendMyIP_Sim
TxSendMyIP_Sim
- BYTE
RxSkipBytes
RxSkipBytes
- BYTE
- BYTE
Count
CreateIPSocket
CreateIPSocket
- BYTE
- BYTE
Protocol
- BYTE
Broadcast
- BYTE
SetDestination
SetDestination
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
| Port High Byte
- BYTE
Dst_Port_Lo
| Port Low Byte
- BYTE
CreateTCPSocket_Sim
CreateTCPSocket_Sim
| This macro creates a socket for sending and receiving TCP data.
- BYTE
- BYTE
Src_Port_Hi
| Port High Byte
- BYTE
Src_Port_Lo
| Port Low Byte
- BYTE
GetSocketStatus_Sim
GetSocketStatus_Sim
| This returns the state of the requested channel's socket.
- BYTE
- BYTE
TxEnd_Sim
TxEnd_Sim
| Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE
RxReadString_Sim
RxReadString_Sim
| A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE
- BYTE
Length
- STRING
RxMatchMyIP_Sim
RxMatchMyIP_Sim
- BYTE
- BYTE
TxStart
TxStart
- BYTE
CreateMACSocket_Sim
CreateMACSocket_Sim
| This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE
Promiscuous
| Receive everything (1) or just data bound for your MAC (0)
- BYTE
Broadcast
| Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE
Error
| Allowsmessages with errors to be accepted (1) or rejected (0)
- BYTE
TCPListen_Sim
TCPListen_Sim
| This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE
RxReadByte
RxReadByte
- BYTE
- BYTE
CreateUDPSocket
CreateUDPSocket
| This macro creates a socket for sending and receiving UDP data.
- BYTE
- BYTE
Src_Port_Hi
| Port High Byte
- BYTE
Src_Port_Lo
| Port Low Byte
- BYTE
RxMatch_6_Bytes
RxMatch_6_Bytes
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
Byte5
- BYTE
Byte6
- BYTE
TCPConnect_Sim
TCPConnect_Sim
| This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
| High Byte of destination port
- BYTE
Dst_Port_Lo
| Low Byte of destination port
- BYTE
RxMatch_2_Bytes
RxMatch_2_Bytes
| This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
TxEnd
TxEnd
- BYTE
RxReadString
RxReadString
- BYTE
- BYTE
Length
- STRING
CreateTCPSocket
CreateTCPSocket
- BYTE
- BYTE
Src_Port_Hi
| Port High Byte
- BYTE
Src_Port_Lo
| Port Low Byte
- BYTE
RxDataAvailable
RxDataAvailable
- BYTE
- BYTE
TxSendByte
TxSendByte
| This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE
- BYTE
Data
TCPListen
TCPListen
- BYTE
TxSendByte_Sim
TxSendByte_Sim
- BYTE
- BYTE
Data
RxFlushData
RxFlushData
| Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE
TCPConnect
TCPConnect
- BYTE
- BYTE
Dst_IP0
- BYTE
Dst_IP1
- BYTE
Dst_IP2
- BYTE
Dst_IP3
- BYTE
Dst_Port_Hi
- BYTE
Dst_Port_Lo
- BYTE
RxReadByte_Sim
RxReadByte_Sim
- BYTE
- BYTE
RxMatchMyMAC
RxMatchMyMAC
| This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE
- BYTE
RxFlushData_Sim
RxFlushData_Sim
- BYTE
RxDataSize
RxDataSize
| This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE
- UINT
CreateMACSocket
CreateMACSocket
- BYTE
Promiscuous
- BYTE
Broadcast
- BYTE
Error
- BYTE
CreateUDPSocket_Sim
CreateUDPSocket_Sim
- BYTE
- BYTE
Src_Port_Hi
| Port High Byte
- BYTE
Src_Port_Lo
| Port Low Byte
- BYTE
TxSendMyMAC
TxSendMyMAC
- BYTE
RxMatch_4_Bytes_Sim
RxMatch_4_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
Byte3
- BYTE
Byte4
- BYTE
RxDataSize_Sim
RxDataSize_Sim
- BYTE
- BYTE
RxMatch_2_Bytes_Sim
RxMatch_2_Bytes_Sim
- BYTE
- BYTE
Byte1
- BYTE
Byte2
- BYTE
RxMatchMyMAC_Sim
RxMatchMyMAC_Sim
- BYTE
- BYTE
TCPClose
TCPClose
- BYTE
GetSocketStatus
GetSocketStatus
- BYTE
- BYTE
