Component: TCP/IP (EB023 v2) (E-blocks 1)
Revision as of 11:52, 3 February 2023 by Wiki bot (talk | contribs)
Version 2.0
Category E-blocks 1
TCP/IP component
TCP/IP component designed to work with the WIZ810MJ module from Wiznet, as used on version 2 EB023 E-block and the MIAC Industrial Addon module.
Please click here to download the component source project: FC_Comp_Source_TCPIP_EB023-00-2_EB.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_EB023-00-2_EB.fcfx
TxSendMyIP
TxSendMyIP
This macro fills the specified channel's transmit buffer with 4 bytes of data representing this Internet E-Block's IP address as specified in the component's property page.
- BYTE Channel
Specifies the communications channel 0-3
RxMatchMyIP
RxMatchMyIP
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's IP address.
- BYTE Channel
RxMatch_4_Bytes
RxMatch_4_Bytes
This macro returns a non-zero value when the next 4 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
Specifies the value of the first byte
- BYTE Byte2
Specifies the value of the second byte
- BYTE Byte3
Specifies the value of the third byte
- BYTE Byte4
Specifies the value of the fourth byte
SetMyIP
SetMyIP
This macro sets up the Internet E-Block's own IP address. In most circumstances, this macro will not be required as the IP address setting in the component property page will remain constant throughout your application.
- BYTE IP0
First Byte of IP address
- BYTE IP1
Second Byte of IP address
- BYTE IP2
Third Byte of IP address
- BYTE IP3
Fourth Byte of IP address
TxSendString
TxSendString
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a string of information.
- BYTE Channel
- STRING Data
Data byte to append to Tx buffer.
- BYTE Length
RxReadHeader
RxReadHeader
Once data in a particular channel has been received, the header will be filled with information about the received data. This macro will return the information in the header. The idx parameter specifies which byte of information in the header to read
- BYTE Channel
- BYTE Idx
Specifies the byte index to return
RxSkipBytes
RxSkipBytes
Often when receiving data packets, it may be necessary to ignore large sections of the data. This can be achieved by reading each byte individually (and ignoring the returned data), but a better way is to use this Rx_skipbytes macro.
- BYTE Channel
- BYTE Count
Specifies how many bytes to skip
MIAC_Module_SetData
MIAC_Module_SetData
- BYTE Count
- BYTE D0
- BYTE D1
- BYTE D2
- BYTE D3
- BYTE D4
- BYTE D5
CreateIPSocket
CreateIPSocket
Note that sockets on up to 4 channels can be simultaneously opened and these channels are numbered 0 to 3. Note that sockets with different modes can be opened on different channels.
- BYTE Channel
- BYTE Protocol
Specifies which IP protocol to use
- BYTE Broadcast
Allows broadcast type packets to be sent and received
SetDestination
SetDestination
This is used in IP and UDP modes to set the destination of the intended data transfer. The destination IP address needs to be set for both IP and UDP modes.
- BYTE Channel
- BYTE Dst_IP0
Specifies the first byte of an IP address
- BYTE Dst_IP1
Specifies the second byte of an IP address
- BYTE Dst_IP2
Specifies the third byte of an IP address
- BYTE Dst_IP3
Specifies the fourth byte of an IP address
- UINT Dst_Port
Destination Port
MIAC_Module_GetData
MIAC_Module_GetData
- BYTE Index
TxStart
TxStart
This macro indicates the start of data transmission for the specified buffer. In TCP mode, data transmission can only begin once the socket has become established. In other modes, data transmission can occur as soon as the socket has been opened.
- BYTE Channel
MIAC_Module_Message
MIAC_Module_Message
- UINT CAN_ID
- UINT CMD_ID
RxReadByte
RxReadByte
A call to this macro will return a byte of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
CreateUDPSocket
CreateUDPSocket
This macro creates a socket for sending and receiving UDP data.
- BYTE Channel
- UINT Src_Port
Port Number
RxMatch_6_Bytes
RxMatch_6_Bytes
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 2 bytes and 4 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
- BYTE Byte5
Specifies the value of the fifth byte
- BYTE Byte6
Specifies the value of the sixth byte
RxMatch_2_Bytes
RxMatch_2_Bytes
This macro returns a non-zero value when the next 2 bytes of data in the specified channel's reception buffer are the same as those passed as parameters. There are similar functions that check for 4 bytes and 6 bytes.
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
TxEnd
TxEnd
Once the transmit buffer has been filled with data, call this macro to actually send the data.
- BYTE Channel
RxReadString
RxReadString
A call to this macro will return a string of data in the reception buffer of the specified channel. It will also internally increment a pointer to that data so that the next call to 'Rx_readbyte' (or any other read function) will read the next byte
- BYTE Channel
- BYTE Length
- STRING Return
CreateTCPSocket
CreateTCPSocket
This macro creates a socket for sending and receiving TCP data.
- BYTE Channel
- UINT Src_Port
Port Number
RxDataAvailable
RxDataAvailable
This macro is used to check whether or not data has been received by the Internet E-Block. A return value of zero indicated that no data has been received. A positive return value indicates that data is available.
- BYTE Channel
MIAC_Module_PushData
- BYTE Data
TxSendByte
TxSendByte
This macro fills the specified channel's transmit buffer with data. It can fill the buffer with a single byte of data, or with a string of information.
- BYTE Channel
- BYTE Data
TCPListen
TCPListen
This macro puts a previously opened TCP channel in "passive open" mode. This is the required mode when writing a TCP server application (e.g. a web server to display HTML web pages).
- BYTE Channel
TxSendByte_Sim
TxSendByte_Sim
- BYTE Channel
- BYTE Data
RxFlushData
RxFlushData
Once data reception has been completed, this macro should be called to discard the data packet and allow other data packets to be read.
- BYTE Channel
TCPConnect
TCPConnect
This macro puts a previously opened TCP channel in "active open" mode. This is the required mode when writing a TCP client application (e.g. using SMTP to send an email).
- BYTE Channel
- BYTE Dst_IP0
- BYTE Dst_IP1
- BYTE Dst_IP2
- BYTE Dst_IP3
- UINT Dst_Port
Destination Port
RxReadByte_Sim
RxReadByte_Sim
- BYTE Channel
RxMatchMyMAC
RxMatchMyMAC
This macro returns a non-zero value when the next 6 bytes of data in the specified channel's reception buffer are the same as the Internet E-block's MAC address entered in the component's property page.
- BYTE Channel
RxFlushData_Sim
RxFlushData_Sim
- BYTE Channel
RxDataSize
RxDataSize
This macro is used to detect the size of data collected by the Rx_data_available macro.
- BYTE Channel
CreateMACSocket
CreateMACSocket
This macro creates a socket for sending and receiving Ethernet data using raw data.
- BYTE Promiscuous
Receive everything (1) or just data bound for your MAC (0)
- BYTE Broadcast
Allows broadcast messages to be accepted (1) or rejected (0)
- BYTE Error
Allowsmessages with errors to be accepted (1) or rejected (0)
CreateUDPSocket_Sim
CreateUDPSocket_Sim
- BYTE Channel
- UINT Src_Port
Port Number
TxSendMyMAC
TxSendMyMAC
This macro fills the specified channel's transmit buffer with 6 bytes of data representing this Internet E-Block's MAC address as specified in the component's property page.
- BYTE Channel
SetMACAddress
SetMACAddress
This macro sets up the Internet E-Block's MAC address. In most circumstances, this macro will not be required as the MAC address setting in the component property page will remain constant throughout your application.
- BYTE MAC0
First Byte of address
- BYTE MAC1
Second Byte of address
- BYTE MAC2
Third Byte of address
- BYTE MAC3
Fourth Byte of address
- BYTE MAC4
- BYTE MAC5
Fifth Byte of address
RxMatch_4_Bytes_Sim
RxMatch_4_Bytes_Sim
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
- BYTE Byte3
- BYTE Byte4
RxDataSize_Sim
RxDataSize_Sim
- BYTE Channel
SetSubnetMask
SetSubnetMask
This macro sets up the Internet E-Block's Subnet Mask. In most circumstances, this macro will not be required as the subnet mask setting in the component property page will remain constant throughout your application.
- BYTE IP0
- BYTE IP1
- BYTE IP2
- BYTE IP3
RxMatch_2_Bytes_Sim
RxMatch_2_Bytes_Sim
- BYTE Channel
- BYTE Byte1
- BYTE Byte2
RxMatchMyMAC_Sim
RxMatchMyMAC_Sim
- BYTE Channel
TCPClose
TCPClose
When an established TCP connection has finished transmission of data, either the local application (i.e. your code) or the remote application (i.e. the application at the other end of the connection) can initiate closure of the socket.
- BYTE Channel
GetSocketStatus
GetSocketStatus
This returns the state of the requested channel's socket.
- BYTE Channel
SetGateway
SetGateway
This macro sets up the Internet E-Block's Gateway address. In most circumstances, this macro will not be required as the gateway address setting in the component property page will remain constant throughout your application.
- BYTE IP0
- BYTE IP1
- BYTE IP2
- BYTE IP3
SPI Channel selector
Prescale
Prescale option selector
MOSI
MISO
CLK
CS / SS
Gateway IP
Gateway0
Gateway1
Gateway2
Gateway3
Subnet Mask
Subnet0
Subnet1
Subnet2
Subnet3
IP Address
IP0
IP1
IP2
IP3
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
Sim Type
Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / API - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
SPI Simulation
API
