| Author
Matrix TSL
| Version
2.2
| Category
Comms: Networking
TCP/IP (ENC28J60) component
A set of routines used to control a ENC28J60 TCP/IP Module. Required connections VCC, Reset, GND, SCK, MISO, MOSI, CS. Leave these pins disconnected CLKOUT, ENC_WOL, ENC_INT
Please click here to download the component source project: FC_Comp_Source_TCPIP_ENC28J60.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TCPIP_ENC28J60.fcfx
SetMyIPAddress
SetMyIPAddress
| Allows the IP Address specified in the component properties to be overridden. The IP Address will revert back to the IP specified in the component properties as part of the initialise macro.
- BYTE
IP0
| IP Address Parameter - e.g. 192
- BYTE
IP1
| IP Address Parameter - e.g. 168
- BYTE
IP2
- BYTE
IP3
| IP Address Parameter - e.g. 250
PacketSend
PacketSend
| Attempts to transmit a data packet to the ENC28J60 module.
- UINT
Length
MakeTcpSynackFromSyn
- UINT
Port
MakeArpRequest
MakeArpRequest
| [[File:]] -
ServerIP
InitialiseDataLengthInfo
| Initialises the data pointers to allow us to craft a response containing data
MakeTcpAckFromAny
MakeTcpAckFromAny
- UINT
Port
PacketReceive
PacketReceive
| Attempts to receive a data packet from the ENC28J60 module. Returns the number of bytes received.
- UINT
CheckForTCPType
CheckForTCPType
| Checks to what kind of TCP type the received data is requesting. Returns a bit field specifying the type of request. 0x01 = Ack Requires, 0x02 = Synchronise 0x10 = Ack
- BYTE
CheckArpPacketIsMyreplyArp
- BYTE
CheckForIp
CheckForIp
| Checks to see if the received data is an IP request with my IP address.
- UINT
Length
- BYTE
CheckForTCPPort
CheckForTCPPort
| Checks to see if the received data is requesting the server port
- UINT
Port
- BYTE
CheckForPing
CheckForPing
| Checks to see if the received data is a Ping request
- BYTE
GetModuleRevision
GetModuleRevision
| Requets the module revision number and returns the value supplied by the module's firmware.
- BYTE
MakeTcpAckWithData
MakeTcpAckWithData
- UINT
DataLength
SetMyMACAddress
SetMyMACAddress
| Allows the MAC Address specified in the component properties to be overridden. The MAC Address will revert back to the MAC specified in the component properties as part of the initialise macro.
- BYTE
MAC0
| MAC Address Parameter
- BYTE
MAC1
- BYTE
MAC2
- BYTE
MAC3
- BYTE
MAC4
- BYTE
MAC5
MakeArpAnswerFromRequest
ReadArrayFromBuffer
ReadArrayFromBuffer
| Reads an array of bytes from the buffer at location specified for the number of bytes specified. If a space character is encountered then the macro will return straight away without the space character in the string.
- UINT
BufferLocation
- BYTE
NumberOfBytes
| Number of bytes to read from the buffer and store into string
- BYTE
Data
ReadRegister
ReadRegister
| Reads the value from a single register onboard the ENC28J60 module.
- BYTE
Address
- BYTE
CheckForARP
CheckForARP
| Checks to see if the received data is an ARP request with my IP address.
- UINT
Length
- BYTE
ClientSendPacket
ClientSendPacket
- UINT
DestPort
- UINT
SourcePort
- BYTE
Flags
- BYTE
MaxSegmentSize
- BYTE
ClearSeqAck
- UINT
NextAckNum
- UINT
DataLength
- BYTE
DestMac
- BYTE
DestIp
MakeEchoReplyFromRequest
- UINT
Length
ControlLEDs
ControlLEDs
| Allows both the LEDs on the Ethernet socket to be controlled. Useful for checking if the SPI communications are functioning correctly.
- BYTE
Mode
| 0=Off, 1=On, 2=Auto
GetDataLength
GetDataLength
| Returns the number of received data bytes after the headers
- UINT
GetTcpDataPointer
GetTcpDataPointer
- UINT
WriteRegister
WriteRegister
| Writes a value to a single register onboard the ENC28J60 module.
- BYTE
Address
- BYTE
Data
FillTcpData
FillTcpData
- UINT
Position
- STRING
Data
- UINT
ReadStringFromBuffer
| Reads a string from the buffer at location specified for the number of bytes specified. If a space character is encountered then the macro will return straight away without the space character in the string.
- UINT
BufferLocation
- BYTE
NumberOfBytes
- STRING
GetSendersMAC
GetSendersMAC
| Gets the MAC address from locations 6-11 of the IP Header
- BYTE
MAC
| 6-byte Array to store the MAC address
FillTcpArray
FillTcpArray
- UINT
Position
- UINT
Count
- BYTE
Data
| Initialises the SPI connection to the TCPIP module and sets up some initial values. Flashes the LEDs on and off twice to confirm SPI comms are active. LEDs are then configured to auto functionality.
TCP IP Specifics
Server Port
| Sets the server's TCP/IP port address which is used to filter incoming TCP packets.
Buffer Size
| Number of bytes to use for the transmit and receive buffer, we actually use this +1 to allow for a null termination. 8-bit PICs should set this to 255 to allow compilation to succeed. Other devices can have larger buffers. Default = 500
SPI Settings
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Reset Pin
MAC Address
MAC0
MAC1
MAC2
MAC3
MAC4
MAC5
IP Address
IP0
IP1
IP2
IP3
Sim Type
| Decides how to perform the simulation of the component. TCP IP - Communicates using the Windows TCP IP communications DLL SPI / API - Communicates using the CAL SPI to allow the communications to be analysed and debugged.
SPI Simulation
API
