| Author
Matrix Ltd
| Version
1.0
| Category
Environmental
Temperature Sensor (Grove 101020015) component
Temperature Sensor uses a thermistor to measure ambient temperature. The resistance of thermistor changes based on ambient temperature. This resistance value alters the output of a voltage divider which is measured by an analog input pin and converted to a temperature value. The operating range is -40 to 125°C , with an accuracy of 1.5°C .
Please click here to download the component source project: FC_Comp_Source_TemperatureSensor.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_TemperatureSensor.fcfx
GetTempInt
GetTempInt
| Reads the temperature of the temperature sensor and returns as an integer value.
- INT
GetTempFloat
GetTempFloat
| Reads the temperature of the temperature sensor and returns as a floating point value.
- FLOAT
Tang Color
| Colour of the moving part of the slider.
Marker Color
| Colour of the marker line across the slider tang.
| Analogue input channel - which pin is the analogue input conected to?
Settings
VRef voltage
| Used by the GetVoltage or GetString component macros to take an ADC reading and convert it into a Voltage. +VRef voltage x 10mV Default 500 = 5.0V
VRef option
| Defines what is used as the ADC maximum reference. ADC Range = GND to VRef Voltage. VDD - Defines the microcontrollers power supply pin as the max reference, VREF+ Pin - Dedicated pin on the microcontroller to allow for a variable reference voltage.
Conversion speed
| Clock setting to select how fast the ADC peripheral will perform an ADC conversion. The FRC setting is based on a RC time base and so will vary with temperature and pressure. Other settings are generally based on divisions of the master clock.
Aquisition cycles
| Number of micro seconds to wait for the ACD input to charge before starting the analogue sample.
Bit Depth
| Maximum number of digital bits the ADC can sample. 8 bit = ADC range 0 - 255 10 bit = ADC range 0 - 1023 12 bit = ADC range 0 - 4095
