Component: UART Software (Timer) (Comms: Interface)
| Author | MatrixTSL |
UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
Please click here to download the component source project: FC_Comp_Source_UART_Software_Timer.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_UART_Software_Timer.fcfx
Simple example showing how to enable a timer interrupt at the desired baud rate then receive a string. If anything is received then it will be echoed back out and displayed on a LCD
SendString
| SendString | |
| Sends an string to the transmit buffer | |
| Data | |
ReceiveArray
| ReceiveArray | |
| Gets an array of values from the receive buffer. Returns number of values received. | |
| Values | |
| NumValues | |
| Timeout | |
| Time in milliseconds to wait for data | |
SendArray
| SendArray | |
| Sends an array of values to the transmit buffer | |
| Values | |
| NumValues | |
UART_Timer_Process
| UART_Timer_Process | |
| Called as part of a timer interrupt at the specific UART baud rate. | |
ReceiveValue
| ReceiveValue | |
| Gets a single value from the receive buffer | |
| Timeout | |
SendValue
| SendValue | |
| Sends a single value to the transmit buffer | |
| Value | |
CheckBuffer
| CheckBuffer | |
| Returns the number of values in the transmit or receive buffer | |
| Buffer | |
| 0=Transmit / 1=Receive | |
ReceiveString
| ReceiveString | |
| Gets a string from the receive buffer | |
| MaxChars | |
| Timeout | |
| Initialises the UART component pins ready to send and receive data | |
