Component: Switch Array Template (Development)
Revision as of 11:53, 3 February 2023 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd. |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gra...")
Author Matrix Ltd.
Version 2.0
Category Development
Switch Array Template component
A base component for creating an evenly spaced array of switches. Each will be connected to sequential pins of a given I/O port. Set target object to point at any standard switch component to change the type of switch used by the array.
Please click here to download the component source project: FC_Comp_Source_switch_array.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_switch_array.fcfx
Here is an example Flowcode program to read the values of a switch array. Switch Array Here is a schematic of how to connect a basic switch to a microcontroller pin.
The resistors are required for correct operation because when a microcontroller's input pin is essentially connected to nothing it will pick up noise in the environment and provide inconsistent readings. This state is referred to as floating i.e. the pin is floating. To test this remove the resistors (if possible) and touch the unconnected switch pins with your finger the output LEDs from the example file above will toggle on and off at high speed.
(5V / 11K) * 10K = 4.54545V
ReadState
ReadState
Read the state of the switch at the given index.
- BYTE Index
The switch to read the status of.
- BOOL Return
WaitUntilHigh
WaitUntilHigh
Pause the program until the switch at the given index is turned on.
- BYTE Index
Index of the switch to wait for.
ReadAll
ReadAll
Reads all of the switches at once, returning a byte containing one bit per switch.
GetHandle
GetHandle
Retrieves the object handle of the switch component at the given index.
- BYTE Index
- HANDLE Return
WaitUntilLow
WaitUntilLow
- BYTE Index
Count
The number of LEDs in the array from 1 to 8.
Input Mode
Choose a single port for all LEDs - pins are allocated in sequence from pin 0 - 7 ...or choose 'Custom pins' to assign each switch individually.
Port
Polarity
Active High = LEDs light when the chosen chip pin is ON Active Low = LEDs light when the chosen chip pin is OFF
Debounce
Time in milliseconds allowed for the pin to settle following a change of state.
Operation
Sets whether switches toggle or are press/release. NB) This option can only be set when the original target includes this option.
Alignment
Which 3D axis to align the copies along.
Spacing
The distance between LEDs in the array. LEDs will be spaced symmetrically around the component centre. Use a negative value to reverse the order of the LEDs.
Reverse
Whether to reverse the order of the switches.
Show Labels
Whether to show labels giving each switch's pin connection.
Label color
Color of the port and pin labels
Shape
Target Switch
To use a custom switch design... - Drag any switch component onto the panel, or create your own using the 'Switch base' - Give your new switch a memorable name. - Choose the new switch in this property; copies will be made to fill the array, and the original is hidden. When unconnected, it will use a default 'basic switch'.
