| Author
Matrix TSL
| Version
2.0
| Category
E-blocks 1
Accelerometer component
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. Useful for approximating Pitch and Roll or for detecting acceleration. Also available in the form of the EB068 Accelerometer E-block.
Please click here to download the component source project: FC_Comp_Source_temp/Accelerometer_EB068.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Accelerometer_EB068.fcfx
CollectXYZData
CollectXYZData
| Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
- BYTE
Axis
- INT
| Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
- BYTE
SimReset1G
SimReset1G
| Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
SimSetXYZ
SimSetXYZ
| Allows the XYZ slider values to be set via the simulation
- INT
X
- INT
Y
- INT
Z
UpdateXYZData
UpdateXYZData
| Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
- BYTE
Write_Register
Write_Register
| Writes a data value to a specific register on the accelerometer
- BYTE
Reg
- BYTE
Data
Bit Depth
| The number of binary bits used to store the sensor's X,Y,Z readings.
Bus Type
| The interface used to talk to the accelerometer. I2C - Two Wire Interface SDA / SCL SPI - Four Wire Interface MISO / MOSI / SCK / CS
Data Rate
| Configures how often the sensor collects a new reading. More often = better instant reaction to new events Less often = more stable results
Scale
| The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Int Option
| Sets if we use the interrupt pin to check if new data is available
Power Option
| Sets if the sensor is always powered or powered via a microcontroller output pin.
Interrupt Pin
| Interrupt pin from the sensor, checked when performing an update to see if the sensor has new data available.
Power Pin
| Power pin if the sensor is powered from an I/O pin.
SPI Connections
| SPI Channel selector
Prescale
| Prescale option selector
MOSI
MISO
CLK
CS / SS
| Chip Select / Slave Select Pin Master Mode: General purpose output pin used to select the remote SPI device. Slave Mode: Hardware chip select pin input used to select the SPI device.
Simulation Coms
| Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - Injector etc
