API Panel.Position.Get
<sidebar>API contents</sidebar> Gets a handle to an object representing the components current position
HANDLE Handle
- The position or component to read from
Returns the handle to an object representing the components current position
Obtaining a handle to a component provides the ability to hold information about the position and coordinates of that component at the time the api is called. This has several uses for example tracking a position of an object prior to any changes to it's parameters. A good example how this is used can be seen by looking at the source code for the example provided in the API Panel.Position.Set wiki page.
- Add to a calculation icon:
result = ::Panel.Position.Get(handle)
