Component: Bluetooth v2 (EB024, Generic AT) (Wireless)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Author Matrix Ltd.
Version 2.1
Category Wireless
Bluetooth v2 (EB024, Generic AT) component
Low level routines for controlling a standard AT Bluetooth interface. Also available in the form of the EB024 Bluetooth E-block. Uses an interrupt to receive characters from the UART and improve reliability, Must be used with a hardware channel.
Please click here to download the component source project: FC_Comp_Source_temp/Bluetooth_V2.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/Bluetooth_V2.fcfx
Making a device discoverable
Example program to set up the Bluetooth module to be discoverable with a pair key. Any data received is then output onto the LCD component. You can connect to the Bluetooth device using a PC with Bluetooth connection and using software such as Flowcode 6, RealTerm or HyperTerminal. Alternatively you can connect using a smart phone running a terminal emulator app or via another embedded Bluetooth board. FC6 Icon.png Bluetooth Discover Script 1 contains the AT commands to setup the Bluetooth device to be discoverable with pair key "1234".
Searching for a device
Example program to scan for local discoverable Bluetooth devices. For each device found the MAC address is displayed on to the LCD. FC6 Icon.png Bluetooth Inquiry
Connecting to a device
Example program to connect to a specific Bluetooth device address and send data to the device. FC6 Icon.png Bluetooth Connect The device MAC address is specified using the "CreateCommandString" and "SendCommand" macros.
Fc9-comp-macro.png Initialise
Sets up the Bluetooth module. Returns 0 for OK, 255 for no reply and 254 for command fail.
ReadString
Fc9-comp-macro.png ReadString
Copies the incoming data from the data string array to a local string variable.
Fc9-u8-icon.png - BYTE NumBytes
ReceiveByte
Fc9-comp-macro.png ReceiveByte
Receives a single data byte from the Bluetooth module. 0xFF signifies no data available.
Fc9-u8-icon.png - BYTE Timeout
Amount of time to wait in milliseconds 0=Wait forever
RestoreFactorySettings
Fc9-comp-macro.png RestoreFactorySettings
Restores the factory settings to firmware using the AT&F* command. Returns 0 to indicate success
SaveSettings
Fc9-comp-macro.png SaveSettings
Saves the current settings to firmware using the AT&W command followed by the ATZ command. Returns 0 to indicate success
SendByte
Fc9-comp-macro.png SendByte
Sends a single data byte out to the Bluetooth module.
Fc9-u8-icon.png - BYTE Data
SendCommand
Fc9-comp-macro.png SendCommand
Sends a command string to the Bluetooth module. 0 = Command sent ok, 255 = No Reply
Fc9-string-icon.png - STRING Command
Fc9-u8-icon.png - BYTE SendCR
Fc9-u8-icon.png - BYTE DiscardReply
0=Do not touch the reply, 1=Wait for reply and remove from buffer
SendScript
Fc9-comp-macro.png SendScript
Send an AT command script. Returns 0 for fail, 1 for success and 255 for unrecognised script idx.
Fc9-u8-icon.png - BYTE idx
SendString
Fc9-comp-macro.png SendString
Sends a string to the Bluetooth module.
SetMode
Fc9-comp-macro.png SetMode
Sets the bluetooth mode to be discoverable and or connectable. Returns 0 for success.
Fc9-u8-icon.png - BYTE Discoverable
0 = Not Discoverable, 1 = Discoverable
Fc9-u8-icon.png - BYTE Connectable
0 = Not Connectable, 1 = Connectable
SetPairKey
Fc9-comp-macro.png SetPairKey
Sets the 4 digit Bluetooth pair key based on a string of numbers. e.g. "1234" Returns 0 to indicate success
Fc9-string-icon.png - STRING PairKey
Key to use as the Pair key, e.g. "1234" or "0000"
Fc9-conn-icon.png Bluetooth Settings
Fc9-type-14-icon.png String Array Size
Amount of RAM memory to dedicate to receiving responses from the BT module. Default 40
Fc9-type-7-icon.png Expect Echo
Sets if we expect an echo of any data we send out to the GSM modem. Most AT type modems (e.g. GSM modules) will automatically echo back incoming data.
Fc9-type-10-icon.png Device Name
Sets the friendly name of the Bluetooth device.
Fc9-type-10-icon.png Pair Key
Fc9-type-7-icon.png Restore Defaults
Is the Bluetooth module reset to factory settings at startup?
Fc9-type-7-icon.png Discoverable
Is the Bluetooth module discoverable by default?
Fc9-type-7-icon.png Connectable
Is the Bluetooth module connectable by default?
Fc9-type-16-icon.png Script Count
Maximum number of scripts to store in the device's ROM
Fc9-type-11-icon.png Script1
ASCII based AT command data stored in ROM and used when sending script 1
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Fc9-type-5-icon.png Reset Pin
Fc9-conn-icon.png Simulation
Fc9-type-10-icon.png Label
Textual label shown on the component I/O flasher
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
