Component: DC Motor (Mechatronics)
Revision as of 11:59, 3 February 2023 by Wiki bot (talk | contribs)
Version 1.2
Category Mechatronics
DC Motor component
DC Motor that can be driven in one or both directions using digital output pins, PWM or HBRIDGE peripherals.
Please click here to download the component source project: FC_Comp_Source_temp/DCMotor_2d.fcfx
Please click here to view the component source code (Beta): FC_Comp_Source_temp/DCMotor_2d.fcfx
DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master. DALI Slave Example1
For a DALI Master example see: Component: DALI Master (Comms: System)
Break
Break
Actively drives both ends of the motor by setting the pins according to the 'Brake Pattern' property.
Coast
Coast
Turn off power to the motor by setting the pins according to the 'Coast Pattern' property.
Disable
Disable
Disable the motor output
Enable
Enable
Enables the motor output
Forwards
Forwards
Set the motor turning in the forwards direction by setting the pins according to the 'Forwards Pattern' property.
- UINT Duty
Sets the motor power for PWM or H-Bridge outputs
GetSimAngle
GetSimAngle
Gets the angle of the simulated motor shaft in degrees.
- FLOAT Return
Reverse
Reverse
Set the motor turning in the reverse direction by setting the pins according to the 'Reverse Pattern' property.
- UINT Duty
Control Type
Control Method
Controls how the motor is controlled. On/Off requires output pins PWM requires a hardware PWM channel H-Bridge requires a hardware H-Bridge channel
Bridge Type
Enable Method
Decides how the motor outputs are enabled.
PinA
First control pin - set 'pattern' properties below to set the pin's function.
PinB
Second control pin - set 'pattern' properties below to set the pin's function.
Forwards Pattern
The state of pins A and B required to drive the motor in a forwards direction.
Reverse Pattern
States of pins A and B required to drive the motor in a reverse direction.
Coast Pattern
States of pins A and B required to stop the motor.
Brake Pattern
Simulation Settings
Label Colour
Speed
Speed of the motor when turned on. Positive speed -> Counter-clockwsie Negative speed -> Clockwise
